Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 01-18-2012, 08:37 PM   #1
How to remove or clean roofing bull?
I am trying to clean off some black tar like material the roofer put around the drain, he put a lot of it and then threw granules on top, making it impossible to completely close the flashing collar over the drain.
This material has somewhat cured and is very difficult to remove. I am using a knife but not having a lot of luck. Is there some special solvent or method to clean it up good?
miamicuse is offline   Reply With Quote
Old 01-18-2012, 08:42 PM   #2
Disabled wood vet
titanoman's Avatar
Any petroleum or laquer based solvent I would think.
titanoman is offline   Reply With Quote
Old 01-18-2012, 10:13 PM   #3
Doing This Way Too Long
Are you talking about a clamping ring? What's it off for?
OldNBroken is offline   Reply With Quote
Old 01-19-2012, 01:28 AM   #4
It wasn't off.
It was a new install. The roofer smeared bull all over the flashing that was folded over the drain opening, then threw granules over it, then the collar would not close because of the granules and will only screw in partially.
I have remove the collar and now am trying to clean off all the bull and granules over the lip just so the collar will close snuggly. This stuff is impossible to get off it's like trying to get peanut butter off bread.
I tried mineral spirit and not much luck.
Old 01-19-2012, 07:36 AM   #5
Exterior Construction
Windows on Wash's Avatar
Look for something with a bit more tooth like a Goof Off or similar.
Be sure to wear proper protection and treat with caution.
Old 01-19-2012, 08:47 AM   #6
You aren't trying to get it spotless are you? scrape all the bulk of it off with a stiff putty knife/chisel and a hammer. It's messy as hell but it's not intended to come off.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 Yesterday 07:48 PM
Rolled Roofing Leaking and Leaking DIYNewbee Roofing/Siding 9 12-13-2009 10:46 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 10:49 AM
Good equipment to use for carpet cleaning? Beth777 General Discussion 5 08-29-2008 09:16 PM
