How To Overlap 3 Layers Of SA Roofing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-29-2008, 09:35 PM   #1
How to overlap 3 layers of SA roofing?
I have an Eichler home that has an addition. The Addition is near flat. Thanks to your great site here, I decided to go with a self-adhered roofing system. I went with Polyglass.
The guy at the supply company suggested that I roll the base up the side of the curb (I hope that's the right term). And roll the mid and cap layers over the top the curb and put the flashing over that.
All three layers are 3' 3 3/8" wide. So if I have the middle layer and top layer starting at the same spot, the overlaps will pile up on each other. Is this okay? If not, how do i remedy this? Shave the first roll?
Edit: The side with the edition has a conventional gutter instead of a curb. So on that side, all three layers would be starting at the same point.
Any input would be much appreciated. Thank you.
Don P
DonP is offline   Reply With Quote
Old 10-30-2008, 06:58 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That's why you use a full roll, a 1/2 roll, then a full one again.
tinner666 is offline   Reply With Quote
Old 10-30-2008, 11:29 PM   #3
Doing This Way Too Long
Rewards Points: 532
Actually it's best to use thirds so no lap is lining up. If you are terminating with some kind of edge flashing, we usually sandwich the metal between the mid-ply and the cap sheet after priming it.
OldNBroken is offline   Reply With Quote
Old 10-31-2008, 04:49 PM   #4
Pro Slate Roofer
tinner666's Avatar
I agree with OldNBroken. But it sounded like it was only 3 runs. I could have been wrong.
Old 11-04-2008, 02:58 PM   #5
That makes sense. It's what I was thinking when I said "shave". But your suggestion on doing the second roll makes more sense. The roofing supply guy did say he'd normally sandwich the curb flashing between the mid and cap, but since I had such a tall curb it'd be okay to just put it on top.
Thank you for your replies.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 05:32 PM
Roofing felt mattflytx Roofing/Siding 2 09-09-2007 11:01 PM
how much danger in 10+ roof layers? megolf Roofing/Siding 2 04-30-2007 10:25 AM
