How Often Should A Soffit Vent Be? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-04-2013, 09:04 PM   #1
How often should a soffit vent be?
Im going to be redoing my fascia and soffits this weekend. Roof Joists are 2"x6" with 16" centers I do believe. Im putting in solid non-vent soffit's.
How often should I have a soffit vent?
DukeLewis87 is offline   Reply With Quote
Old 04-05-2013, 12:12 AM   #2
Rewards Points: 13,218
Why install any soild vents?
I just do the whole run in vented and use unvented on the gables.
Old 04-05-2013, 01:09 AM   #3
Because I prefer the look and strength over what im choosing.
Old 04-05-2013, 08:12 AM   #4
Then you end up with a warmer roof then it should be which will shorten the life of the shingles, and can cause ice dams.
Trying to understand your logic on strength.
Is there something differant about yours that I'm missing?
If it's a really long over hang then you may need to add some center supports.
Got a picture of that area.
Old 04-05-2013, 08:32 AM   #5
Rewards Points: 2,238
What type of material are you using for the soffit - aluminum, vinyl, wood?
rossfingal is offline   Reply With Quote
Old 04-05-2013, 08:47 AM   #6
Roofmaster
Rewards Points: 2,172
Your soffit should be continuously vented, because atmospheric dirt clogs up the vents pretty fast. There is no appreciable difference in strength between solid and vented. The framing members that support the roof sheathing are called rafters, not joists, whether they are low slope and serve as joists or not. "Rafters" takes precedence in such case.
Hope this helps.
Old 04-05-2013, 04:26 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
got some photos of your overhang/facia board?
you could always install a cornice or facia vent.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-05-2013, 11:05 PM   #8
Dave Sal's Avatar
Rewards Points: 592
There's a formula to determine how much soffit venting is needed based on the square footage of attic space. I think you can find it on building science.com. I have solid wood soffits which is the way the house was built. The builder didn't include soffit vents so I put small ones in myself about a year after buying the house. Then last year I swapped the smaller vents for the larger versions. Made a big difference in that snow doesn't melt for days whereas before it would have started to melt by the next day. I have about 15 soffit vents on each level (2stories).
Dave Sal is offline   Reply With Quote
How to extend HVAC ceiling vent through new soffit? NewHomeDIYGuy HVAC 33 03-26-2012 09:59 AM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
