Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-15-2011, 11:32 PM   #1
How Much Space Between Each Asphalt Shingle?
My three-tab shingles have been in my basement and they are probably at about 65 degrees. I am going to put them on my storage shed tomorrow and it will be about 50 to 55 degrees. Most articles that I have read only say to just run a row of shingles and do not say whether there should be a space between the shingles for expansion. Only found two articles that mentioned spacing. One said do not butt them up tightly against each other and one article said to leave about 1/16 inch between each shingle for expansion.
In one of the questions on this site someone had shingles that had buckled, and someone wrote that when installed the installer did not leave space between shingles for expansion.
I would appreciate any advice as to what space, if any, that I should leave between them, especially with the difference in temperatures between the shingles and the air outside now, and what would happen this summer.
Phil
Phila is offline   Reply With Quote
Old 12-16-2011, 07:55 AM   #2
Pro Slate Roofer
tinner666's Avatar
55 isn't bad. Just a 'visible' gap is all. Not quite in contact with each other. If the dab of sealer is the only thing touching, it won't hurt. 1/64" maybe. A hairline gap is fine.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Snav (12-16-2011)
Old 12-16-2011, 08:54 AM   #3
Disabled wood vet
titanoman's Avatar
I agree. Hairline.
(instructions on package)
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-18-2011, 04:19 PM   #4
Back in the good ole days when i was young and feeding 4 kids and Hallmarks were $45 i figured I could save $20 a roof by using a 1/4" space between shingles
heck gas was up to 65 cents a gallon then
kt82 is offline   Reply With Quote
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 03:10 AM
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing 5 09-26-2009 02:46 PM
Metal roof vs asphalt shingle roof Bob_T Roofing 1 06-20-2009 06:51 PM
Asphalt Shingle Failure WirelessG Roofing 11 03-30-2009 08:44 AM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 07:32 PM
