How Much NFVA For 10x10 Shed? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-04-2013, 12:36 PM   #1
Rewards Points: 113
Question
How much NFVA for 10x10 Shed?
Hi Folks,
I'm a DIYer building a simple 10x10 shed, 8' high walls, 4/12 gable roof pitch, and 12" eaves. No overhang on the ends.
I had planned to put in soffit vents along with a ridge vent. Prior to doing some recent reading, I had no idea that it was important to properly size the venting. Seems obvious now!
I found calculations for the minimum NFA required. It's based on attic floor space. The result is a very small amount if venting required. I'm wondering if I can or should exceed that minimum NFVA amount? I'm looking or any suggestions for how much venting to add to this small shed.
Thanks,
Matt
mklein49 is offline   Reply With Quote
Old 10-04-2013, 02:00 PM   #2
43 years in construction
Arkitexas's Avatar
Note that all code requirements establish minimum acceptable standards. The venting required in building codes is primarily for moisture control in the attic space and is not for heat control. You can always add more ventilation at your option. Keep in mind, that there is a relationship between the net free opening sizes of the high and low opening that should be maintained. The net free area of the high vent(s) (ridge) should be equal to or greater than the sum of the net free areas of all the lower vents (eaves).
Rick
Arkitexas is offline   Reply With Quote
The Following User Says Thank You to Arkitexas For This Useful Post:
mklein49 (10-04-2013)
Old 10-12-2013, 12:00 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,628
+1 to Arkitexas.
You don't really need any given the lack of a conditioned space.
For the ease of install and more leakproof application, I would just throw in some gable end vents. It will breathe enough.
Old 10-13-2013, 09:03 AM   #4
Rewards Points: 236
i agree. and they don't need to be very big at all. but since there will be no overhang, see that they are water shedding.
Fix'n it is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
