-   -   How Many Years Left (http://www.diychatroom.com/f9/how-many-years-left-21487/)
SirDieAlot 05-26-2008 05:29 PM
How Many Years Left
2 Attachment(s)
I was wondering how many years my roof has left.
Some people I have talked to think I need to get it replaced. Others say it has alot of life left.
I did find some of the overhangs that are rotting out due to moisture. Not sure if it something I can easily fix and it is one spot of if I need to replace all of it.
LawnGuyLandSparky 05-26-2008 07:35 PM
None. Stick a fork in it, it's done!
concretemasonry 05-26-2008 08:03 PM
Did you have to pay extra for the neat curved surface of the roofing? Looks like an amateur installation also.
It may last awhile, but it will just get uglier and then even more ugly. Start saving immediately because you will have to do something in the year or two.
How many layers?
MJW 05-27-2008 12:18 AM
I don't see much for amateur installation, but it looks like a lower end shingle the way the laminates are coming apart. As long as you don't mind looking at it, it should be fine for a while longer.
SirDieAlot 05-27-2008 05:48 AM
Originally Posted by concretemasonry (Post 125970)
How many layers?
It looks like only one layer
johnk 05-27-2008 08:46 AM
They look like old organic laminates,I would suggest a re-roof soon.
Ed the Roofer 05-27-2008 11:48 AM
How many years has it been on so far?
It seems as if the material is a bit inferior, due to the excessive curling for a laminated architectural shingle, but that may be a direct result of inadequate ventilation, both fresh air intake and roof top exhaust.
The rotting overhangs are only going to get worse the longer the roof and ventilation stay in the same condition.
Moisture deterioration could be caused by a lack of proper ventilation, or it may be signs of a roof leak.
Are the dark spots wet?
Are they consistent throughout an entire side or even both sides?
I would recommend a complete roof removal and address the causes of the problems when getting a new roof specified.
Ed
the roofing god 05-27-2008 09:42 PM
looks like not enough overhang at the gutter area,shingle condition very poor,looks like owens corning,I would replace at this point,you have enough wrong that it wouldn`t be cost effective to just exchange those areas,and the shingles look to be to brittle to allow for piecemeal repairs
SirDieAlot 05-29-2008 06:42 AM
Ed
I am not sure on how many years for the roof. My guess would be that it has never been replaced which would make it around 30 years.
The Dark spots that you see on each shingle are not wet spots and are consistent across the roof.
SirDieAlot 05-29-2008 06:44 AM
Picture Of some overhang damage
1 Attachment(s)
Here is one some of the overhang damage looks like. As you can see it is wet from the rain that morning.
Ed the Roofer 05-29-2008 09:35 AM
Time for a new roof and soffit board replacement. Also, make sure you have the contractor install 2 rows, 6 feet wide of Grace Ice and Water Shield along all of the gutter eave edges to prevent this type of leak ever occurring again in the future.
Ed
the roofing god 05-29-2008 04:37 PM
what Ed said !!!
SirDieAlot 05-31-2008 12:46 PM
Found It
I found were the water is coming from. I looked outside when it was raining yesterday, and the watter is running down the backside of the facing board. It does not even make it to the gutters.
can this be fixed or is it still roof replacement. I would really like to get just a couple more years out of the roof if possible. I just found out that my siding needs replaced as well.
I am going to get up in the attic and see if the roof as ever been replaced.. If it has not it is 30 years old otherwise I have no clue.
Ed the Roofer 05-31-2008 02:11 PM
I would bet that the material between the slots or keyways is completely burned out and degraded if this is a 30 year old roof. Look at the slot lines between the bottom row of shingles and see.
Do you have these stains coming in every 12" or so?
Some isiots do not even install starter shingles under the first applied course of field application shingles and then the felt paper gets dried out and leaks, but this is usually the sign of a rookie untalented shingler wannabe or a DIY Home Owner project.
Ed
