How Many Times Can A Deck Handle A Re-roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-06-2008, 08:45 AM   #1
Rewards Points: 31
How many times can a deck handle a re-roof?
Plywood deck?
OSB deck?
ShortEdged is offline   Reply With Quote
Old 01-06-2008, 09:24 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,640
Ayuh,.......
It can be Reroofed Forever or until it Rots.......
Whichever comes 1st.....
OSB is much Less forgiving than Plywood in MHOpinion.......
Bondo is online now   Reply With Quote
Old 01-06-2008, 09:31 AM   #3
Rewards Points: 31
Originally Posted by Bondo View Post
Ayuh,.......
What about wood loss from all the nails? Kinda like a stripped out treads for a wood screw?
Old 01-06-2008, 09:34 AM   #4
Building and plumbing
USP45's Avatar
Rewards Points: 150
If the shingles must be replaced so often the you need to worry about plywood life, then the roof must be replaced at the rate of 3 times per week for 60 years. In that case, someone is installing them wrong, or give me the homeowners number, I'd love to work for them
USP45 is offline   Reply With Quote
Old 01-06-2008, 09:44 PM   #5
When you say re-roof, that implies another layer going over the top of the exosting layer(s).
Most codes only allow 2 layers of roofing and some will allow for 3 at a maximum.
When a complete tear-off of any and all existing layers is done, then the condition of the existing deck sheathing can be inspected and repaired as necessary.
Ed
Ed the Roofer is offline   Reply With Quote
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
add roof to patio deck elfyperz Introductions 1 05-17-2006 05:37 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
