Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-31-2012, 03:08 PM   #1
How many holes in blocking?
I'm adding 2x6 blocking to an existing shop. The trusses are 24" O.C. I'm drilling three 2' holes in each block. My question is: Do I need to drill every block to get enough ventalation (I know there needs to be roof vents.) or could I get by with say every other one?
Patrick Allen is offline   Reply With Quote
Old 12-31-2012, 05:19 PM   #2
Exterior Construction
Windows on Wash's Avatar
It is best to vent each one.
How much do you condition the space.
I would rather see 1 - 2" hole per block than 2 - 2" every other one.
Old 12-31-2012, 10:56 PM   #3
Moderator
Depends on how much ventilation you want. With an 18NFVA ridge vent, you need 9NFVA per side of building per foot for balanced system. 2' block is 18"NFVA or 2" circle with screen is about 3"NFVA X 3 = 9NFVA, per foot----- so 6- 2" per block for 1/150, if using a vapor retarder (faced) insulation, 1/2 of that (3-2") for 1/300.
You did say shop...
Gary
Clothes taking longer to dry?
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Patching vinyl siding to "repair" small holes tomseeley Building & Construction 3 06-05-2011 10:12 AM
Holes in yard under tree - what is it? Leah Frances Pest Control 13 05-11-2011 08:22 PM
Holes in flange dont match holes in toilet! ljenkins Plumbing 2 02-06-2010 08:17 AM
Drilling Multiple Holes in Studs rjschwar Building & Construction 6 01-27-2010 02:05 PM
