How Many Bundles Do I Need - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-12-2011, 08:42 AM   #1
How many bundles do I need
I need to buy asphalt shingles for my new garage addition that is sheathed with 5/8" plywood. I am going with architecural GAF brand from Home Depot. I already installed the flashing at the peak, the drip and rake edges and the felt paper.
My roof is 20 x 18 with a 2/12 pitch and no obstructions of any kind.
I just want to make sure I get everything I need.
I figure I need to pickup:
13 bundles of shingles
1 bundle of starter course shingles
1 roll of ice barrier
1 bundle of cap shingles
a few tubes of roofing cement just in case
carton of 1-3/4 roofing nails for my Hitachi roofing gun
How does that list look?
jgcable is offline   Reply With Quote
Old 05-12-2011, 09:01 AM   #2
MJW
11 bundles
1 1/4 roofing nails
1 bundle starters
why do you need ridge? it sounds like you built a lean to roof...
I&W should cover the whole roof with that low pitch
1 roofing cement (if you think you need it)
Just an FYI, you probably could have had someone roof that for you for the price of that gun.
MJW is offline   Reply With Quote
Old 05-12-2011, 09:34 AM   #3
Originally Posted by MJW View Post
11 bundles
1 1/4 roofing nails
1 bundle starters
I need ridge caps because my lean to roof goes to the peak of my existing roof. I already felt papered the roof with 15lb paper. If I install I&W do I put it over the felt?
Regarding the Hitachi gun, I got it used for $80.00.
I tried to get a local roofer to do it but they all want a fortune.
I didn't want to do this part of the job myself. Unfortunately, I have no choice.
Old 05-12-2011, 09:39 AM   #4
Old 05-12-2011, 04:03 PM   #5
MJW
I&W is to be put directly on the sheathing.
Obviously, you can do what you want, but don't waste the money on I&W if you aren't going to put it directly on the sheathing.
Old 05-12-2011, 04:14 PM   #6
Should I only put it on the lower rake edge of the roof? If so, I can always cut back the felt paper and apply it directly to the sheathing.
Old 05-13-2011, 11:39 AM   #7
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
To install shingles on that low of a slope, you need to install either half lapped felt or I&WS on the entire deck. Refer to the installation instructions printed on the wrapper of each bundle. Different brands have different requirements fo the warranty to be in effect.
seeyou is offline   Reply With Quote
The Following 2 Users Say Thank You to seeyou For This Useful Post:
1985gt (05-13-2011), MJW (05-13-2011)
Old 05-16-2011, 07:01 PM   #8
How many bundles do I need ?
Quick question from a rank amateur: Does he need I&W if there is no heat source in the garage? Thanks
sully27 is offline   Reply With Quote
Old 05-17-2011, 08:33 AM   #9
Residential Roofer
Slyfox's Avatar
On a low slope structure like this OP's garage, the additional underlayment requirements are needed for wind driven, slow running and ponding water issues.
Those issues will occur no matter if the garage is heated or not.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
GAF Timberline Shingles kangaroofer Roofing/Siding 31 04-22-2011 07:03 PM
How long can shingle bundles be on roof? tidal9 Roofing/Siding 7 05-29-2008 08:00 PM
Will shingle bundle's tabs melt together? dhavlena Roofing/Siding 11 09-02-2007 12:39 AM
Yuk! Shingle Packaging Is Awful! Docfletcher Roofing/Siding 22 08-26-2007 11:46 PM
Batch Codes On GAF Docfletcher Roofing/Siding 26 08-26-2007 11:17 PM
