How To Make Ridge Cap Shingles With Tabless Architectural Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-09-2009, 09:40 PM   #1
how to make ridge cap shingles with tabless architectural shingles
Can I make ridge cap shingles with my architectural shingles? how do I do this?
kw151002 is offline   Reply With Quote
Old 07-09-2009, 09:43 PM   #2
I don't think it will look right at all
I bought the matching ridge shingles for my roof
Old 07-09-2009, 11:36 PM   #3
The laminated pieces will wind up sticking up and out like a sore thumb.
You can either buy the Hip and Ridge Cap shingles that come pre-perforated from the same manufacturer.....
ot
You can see if the color from the 3-tab from that same manufacturer or another one precisely or even just closely matches the color of the architectural shingle you are installing.
You will regret it if you use the laminated architechturals now and have to replace them in the future.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-10-2009, 08:15 AM   #4
RippySkippy's Avatar
Several years ago I roofed my old house with the same shingles, and just cut up a standard shingle into thirds and angle cut the "upper half" of the shingle (image below) and laid them as normal. I found if I trimed the corners, they laid better. BTW when I shingled my house, I didn't have ready access to the matching ridge caps Now many stores sell them next to the bundles.
My roof was a straight run ranch with a 4/12 pitch. I don't think I would try it with anything steeper as they may not bend and lay flat over the ridge. Nor were they installed over a ridge vent.
They looked fine, I kept watch to see if the layers were separating over the ridge, I suspected they would so I kept an eye out. When I sold the house a couple of years ago...after 10 years it was fine.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 08:12 AM
Does ridge venting make sense if I do not have eaves/soffits? nymark Roofing/Siding 15 06-18-2008 11:59 PM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
Does GAF still make 40yr shingles? Marlin Roofing/Siding 8 10-07-2007 01:49 AM
