How Long Do I Need To Wait To Shingle If My Felt Has Been Rained On? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 08:34 AM   #1
Lost..
Rewards Points: 336
How long do I need to wait to shingle if my felt has been rained on?
As the title asks, I need to know how long I need to wait before I shingle After my felt has been rained on. I had planed on starting to do some shingles after work today, but I don't know if I should shingle over somethng that could be damp. Wouldn't that possibly cause mold or mildew?
Here is a thread with some pictures of the roof.
Small Shop / Garage build thread
J S Machine is offline   Reply With Quote
Old 03-15-2011, 03:34 PM   #2
MJW
Put the sheathing on the walls first. As soon as your done, put the shingles on. Quite the project you got going there. Wouldn't hurt to stop by a few new jobsites if it's possible, to pick up a few pointers just by looking at how things are done.
The shingles will breathe. No worries putting shingles on wet tar paper.
MJW is offline   Reply With Quote
Old 03-15-2011, 03:57 PM   #3
old timer
It will be easier to install if the paper has dried out and there are no buckles to deal with. Easier to chalk lines if needed. Less chance of slipping. etc. But nailing over wet tar paper is not to much of a concern.
dmc@RCR is offline   Reply With Quote
Old 03-20-2011, 12:17 AM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Installing shingles over wet felt can cause premature aging and blistering.I would recommend letting it dry out.
When I did alot of new construction in the past I let it dry.It will be a little bubbled when wet but when it dries it will relax a bit.If you install while its wet and bubbled the shingles won't lay as well as they would on a dry surface.After the roof is installed you can tell where it was bubbled.
Be careful when installing over those symplex(Metal Cap Nails) and hold the nose of your gun flush with the roof.If the gun is angled when you pull the trigger the nail can hit the disc and hit someone beside you or even yourself.
Roofmaster417 is offline   Reply With Quote
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 10:05 AM
How long should I wait to paint texture? bluefitness Painting 1 12-11-2008 12:51 PM
How long can the felt last Hay1966 Roofing/Siding 10 07-07-2008 05:55 PM
How long can shingle bundles be on roof? tidal9 Roofing/Siding 7 05-29-2008 08:00 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
