How Long Can Shingle Bundles Be On Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-20-2008, 04:00 PM   #1
How long can shingle bundles be on roof?
I'm having shingles delivered this weekend, except it's supposed to rain. How long can I leave them on the roof until a dry weekend? I'm in MN so the temp is below 80 degrees so far.
tidal9 is offline   Reply With Quote
Old 05-20-2008, 09:43 PM   #2
They store them in the storage yards on pallets for a long time.
How long are you worried about?
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-22-2008, 10:58 AM   #3
Thank you for the response. I only have the weekends to do the roofing work, so with the unpredicatable weather, it may last a few weeks to a month. I've heard rumors about the heat from the sun melting the shingles together while in the bundles. I was thinking that I could leave them sealed and not stack them on each other to help aleave any pressure/heat. Not sure of any other methods.
Old 05-22-2008, 11:09 AM   #4
You should be just fine with that time period. Just do not stack them higher than 3 bundles on top of each other.
If they do wind up being stuck, just a little bit, then drop them at the center of the bundle on top of the ridge of the roof, but not from shoulder height, just a foot or two, and they will seperate the contact easily.
Ed
Old 05-22-2008, 05:53 PM   #5
Again, thank you so much for the reply and tip. I cannot afford to screw this one up with the investment we made into the materials. Thanks again!
Old 05-22-2008, 05:59 PM   #6
No problem, I am just glad to be able to help out.
Get back with more questions if you are doing this yourself and need some advise about certain situations if you need to.
Ed
Old 05-27-2008, 09:50 PM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
try covering the stacked shingles with white painters tarps to reflect the heat from the bundles
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 05-29-2008, 07:00 PM   #8
Good idea, thanks for the tip!
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Will shingle bundle's tabs melt together? dhavlena Roofing/Siding 11 09-01-2007 11:39 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
