How To Install Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-14-2009, 09:41 AM   #1
How to install flashing
Hello all,
I am a bit of a noob at this, I'll try my best to describe the situation/problem. We are currently in the process of replacing our current roof. After tearing up the old roof, we noticed that there is a bit of damage which resides along the area where the roof meets a stucco wall, I am told that I should use some sort of flashing. Since the roof is fairly old, when it was originally built, there wasn't any flashing installed since the materials were not available at the time. I am told I should use an "L" flashing, how would I install this against my stucco wall? I've attached a link below of what I am trying to describe. My stucco wall is not as tall as what is seen in the image below, the roof kind of drops down a bit to another section. I'll try to get some pictures later, but for the time being I hope my description is able to get some help out there.
Thanks for your help in advance
http://www.dallashomeinspections.com..._wood_wall.JPG
mrconfident is offline   Reply With Quote
Old 06-14-2009, 10:41 AM   #2
MJW
To do it right, you have a mason come in and put flashing in there. Make sure they use steel flashing though instead of the cheapo aluminum.
To DIY without masonry, you can use flat flashing, caulking each indivual one separately. Put a nice bead in there and push the flashing into it. This works much better than putting the flashing in first and caulking just the shingles to the stucco. Use a good quality caulking like OSI or Vulkem, and you shouldn't have any problems with cracking. The next roof will probably need some repairs to the stucco though. This isn't the best option, but it works.
MJW is offline   Reply With Quote
Old 06-14-2009, 11:13 AM   #3
You could install step flashing with your shingles which are weaved in 1 shingle, 1 flashing. When you lay a shingle next to that wall place a step flashing on top of the shingle just high enough for the next shingle to cover it repeat with every course of shingles. And if you are handy enough to tackle your roof you might not need that mason. On your wall snap a line 6 inches above your roof and cut with a grinder with a diamond masonry blade. Now all you need is a peice of metal bent 5 1/2" x 1". This is your counter flashing the 1" side goes into your cut and the 5 1/2" goes over the top of your step flashings use thin fluted masonry nails and nail into your cut wedging the counter flashing but not nailing through it now use some clear silicon or sealant seal that cut in your wall and your good. I recommend geocel sealant and copper flashing plus copper looks great against stone or stucco. Hope this helps if you need any more help or descriptions just reply and I'd be glad to help.
roofah is offline   Reply With Quote
Old 06-15-2009, 03:46 PM   #4
Has your stucco been painted?
Counter flashing to stucco is never a good idea.
stuccoman is offline   Reply With Quote
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 10:50 PM
