How To Install A Flash (for A Vent Pipe ) Properly - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-06-2011, 09:34 AM   #31
Rewards Points: 99
was not perfect, I used a coffee can and lined it out with a marker. It is a circle, looks like a circle but not perfect . As long as it was not hacked and doesnt leak
Gnfanatic is offline   Reply With Quote
Old 06-06-2011, 10:10 PM   #32
Rewards Points: 956
oh ok. in my mind i was thinking it needs to be good enough so it doesnt leak. but that's what the flashing is for...duh haha.
but anyways i think i am going to hire a roofer to come out since i am using spray foam and I don't want to risk anything leaking down the road to ruin anything....what's a rough estimate to install a exhaust fan and cap it? $300?
federer is offline   Reply With Quote
Old 06-06-2011, 10:16 PM   #33
Rewards Points: 1,088
Originally Posted by Gnfanatic View Post
Well, its been a few months and several thunder storms. I have no leaks. thanks for the help guys!
I'm not a plumber and don't know the code, but is it kosher to have 90 degree bends on vent pipes or should they be more steeply angled?
handy man88 is offline   Reply With Quote
Old 06-06-2011, 10:18 PM   #34
Rewards Points: 99
The boiler allows 90 degree bends for venting and intake. I read the manual thoroughly. you deduct so many feet allowed per a bend ( I think 10) plus the town inspector saw everything and gave me a co
Old 06-08-2011, 10:21 PM   #35
Rewards Points: 956
from what i read it's best not to do 90degrees but it can be done
Vent pipe, 2 questions moneymgmt Plumbing 14 12-06-2012 10:37 AM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Leak found - need advice (Vent pipe) krooser78 Plumbing 0 03-29-2010 02:49 PM
Gas stove vent to gas pipe clearance? rbarr110 HVAC 8 06-17-2009 03:36 PM
Vent pipe where new window wants to be moondog111 Plumbing 6 04-19-2008 06:47 PM
