How To Install Corrugated Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-13-2010, 01:05 PM   #1
how to install corrugated metal roof
I am deployed to afghanistan right now, and we are installing a corrugated metal roof. We are trying to find out if there is a specified way of doing it.
1. Should you run from eave to ridge, Then working your way down the roof?
Or should you put the whole first layer going gable to gable,then starting the next layer and so on?
2. should you stagger the seams at all?
Thanksahead of time for any responses.
john.deline is offline   Reply With Quote
Old 08-13-2010, 09:03 PM   #2
Doing This Way Too Long
Rewards Points: 532
If you are not using full-length panels, proceed one run at a time from eave to ridge. STAGGER YOUR JOINTS with the next run. You never want two laps to line up next to each other. Work from gable to gable. Hope this is what you were asking
OldNBroken is offline   Reply With Quote
Old 08-14-2010, 01:03 AM   #3
so why would you not want the 4 sheets overlaping and tieing in together in the same spot seems to me that would be more secure and less screws.
and you do not want to stagger first set of sheets to second sheet to the third sheet?
Old 08-14-2010, 01:17 AM   #4
Rewards Points: 532
because you are stacking up 4 layers of metal in one spot. Staggering eliminates a layer and lines the panels up more consistently. You are going to use the same amount of fasteners either way.
I'm not understanding this...
vertically you run the panels straight up the roof from eave to ridge. horizontally, if you are not using full-length panels, you want to stagger the length of the next panel a few feet above or below the run you just installed.
Old 08-14-2010, 06:04 AM   #5
how to install corrugated roof steel
they ar trying to run from gable to gable with the second run staggered from the first by cutting a sheet in half. then running the next row like the first.
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Shingle to corrugated roof transition help needed!!! ctucker Roofing/Siding 4 07-12-2009 08:44 PM
plumbing vent flashing on metal roof??? red86yota Roofing/Siding 14 02-09-2009 11:40 AM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing/Siding 2 09-12-2008 08:51 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
