How To Handle A 86 Year Old Homeowner-'wont' Use Attic Fan!! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2008, 09:09 PM   #1
Rewards Points: 562
How to handle a 86 year old homeowner-'wont' use attic fan!!
Talked till blue in the face,,,use the da#$%^&*() automatic attic fan PLEASE,,,have set it up and turned it on twice or three times,,,immediately shut off when I leave. HE can hear it run and it bothers him,,,dont know if its the noise OR the electricity it is 'wasting'
NOW he is *****ing cause got a long water streak down the kitchen ceiling,,,says the roof has to be leaking,,'see' it is stained. Has to climb up there and look all the time too,,,dont know why,,he couldnt see it if it DID leak!!
Think this started last winter so could be too much humidity up there,who knows??OR ice sicles. Roof was just reshingled 2 or 3 years ago.
IF I could talk fast enough to use it in summer time,,,so it helps his AC out,,he would cover it all up for winter cause he says lets too much cold air in,,,duh!!
Nothing "I" do is right anyway,,whats new??
ANY suggestions?? Thanks for reading-d-
4just1don is offline   Reply With Quote
Old 06-29-2008, 10:54 PM   #2
Rewards Points: 150
ridge vents ???
comp is offline   Reply With Quote
Old 06-30-2008, 01:28 PM   #3
Rewards Points: 562
No ridge vent,,there are soffit vents with chutes,,forget now if there are regular turtle back roof vents or not,,have to LOOK next time I am there. this roof is mostly hip roof with a L shape to main house to garage
Old 06-30-2008, 01:31 PM   #4
Rewards Points: 150
is that open ,,at the L ?
Old 06-30-2008, 06:33 PM   #5
Get him to change from the PAV to Passive Ventilation via the Ridge Vents, then he will not be able to turn them off.
Ed
Ed the Roofer is offline   Reply With Quote
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Floor an Attic for Storage MrBill_DIY Flooring 5 05-13-2008 06:32 PM
Attic Insulation jim_arnau Building & Construction 13 11-07-2007 08:59 AM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
