How To Get Air Into My Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 05:56 PM   #1
jkk
Rewards Points: 243
How to get air into my attic
I have a ridge vent but only gable vents for intake. My eave is open with 2x6 blocking between the rafters. I need to modify the blocking somehow to let air in. Insulation is blown in, so I'll probably have to add baffles after I mod the blocking. I need about 250 sq inches of intake.
Any suggestions?
jkk is offline   Reply With Quote
Old 07-28-2012, 10:31 PM   #2
Rewards Points: 14,306
The best way would be to knock out all the blocking and add vinyl vented soffit, at the same time remove the gutters and add coil stock over the fashia.
No more painting ever.
Old 07-28-2012, 10:48 PM   #3
Rewards Points: 2,212
Don't forget the insulation stops/air channels
mae-ling is offline   Reply With Quote
Old 07-29-2012, 07:17 PM   #4
jkk
Rewards Points: 243
Well, that's a lot of extra work and dollars, especially since the 20 year old fascia board is in good condition. I'm thinking more along the lines of cutting out a 14" x 2" notch in the top/center of the blocking and covering the hole with 16" x 4" screened vent. I will also add baffles in the attic.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
