#1 |
Unemployed Airline Pilot
how to flash around an existing electric service mast?
I have to put flashing around an existing, and hot, electric service mast. How do you, the professionals, do it? The last roofers didn't do it and it leaked and has cause a few thousand in damages.
I was thinking about slicing a thermoplastic 3" flashing boot laterally and placing it around the mast and appropriately putting it under the 3 tab shingles. Then I would nail it to the roof and THROUGHLY seal all cuts with black silicone II. Does anyone have a better technique? Thanks in advance. Last edited by FlyNaked; 07-31-2009 at 02:05 AM. |
#2 |
Super Moderator
That would work, but clamp off the top part of the boot that goes around the pipe with something like a radiator hose clamp.
Also, there is a product out there now, called Spin Boot or something like that. Here, I found it for you. http://www.spinflashing.com/retrofit-spin-flashing.html Look it up on there website for a distributor near you. Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Ed...
Thank you very much. The Spin-Flashing might just do the trick. :-) |
#4 |
Household Handyman
Now Ed, there you go sharing your neat little tricks with everyone. And I Thank You. That is a neat piece of equipment.
Thanks, David
#5 |
There is a boot made just for that now, it is a residential retrofit flashing www.goldenrulefasteners.com You can't buy from Golden Rule Fasteners unless you are a supply store, but they can tell you where to pick one up. ABC Supply stocks them though, I do know that.
| Display Modes | |
| 200 Amp service really needed for a 830 sq ft house? overkill? | alexz | Electrical | 7 | 11-16-2009 06:54 PM |
| Cost to run electric service to home 500 feet away | skinnersone | Electrical | 2 | 08-26-2007 05:07 PM |
| 200 amp panel with a 100 amp service? | alexz | Electrical | 10 | 07-29-2007 11:00 PM |
| Suspected open/loose service neutral | mrtomwj | Electrical | 5 | 09-28-2006 09:46 AM |
| electric service in garage | kelr | Electrical | 2 | 03-26-2005 09:38 PM |
