Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-03-2009, 04:38 PM   #1
How to fix roof leak
I have a 2 story house with a screened in porch that has a closed in attic area and roof above it. On the roof of the porch where the roof meets the outside wall, there is a vent which appears to be letting water into the living room ceiling. my questions are ...
1. Is the vent suppose to have shingles on it?
2. Is this vent even necessary, since it is just the attic above the screened in porch?
dnafarrell is offline   Reply With Quote
Old 02-03-2009, 05:14 PM   #2
Pro Slate Roofer
tinner666's Avatar
Need pictures.
Frank
tinner666 is offline   Reply With Quote
Old 02-03-2009, 06:46 PM   #3
I have gas!
Clutchcargo's Avatar
It's hard to picture what this looks like.
Another 1000 words should do it or a photo of the problem area.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-03-2009, 08:15 PM   #4
Super Moderator
Also, is it a flat roofing product on there now or is the rest of it shingled and how close to the other roof is it?
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 02-03-2009, 10:38 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
the house has a two story roof with a 1 story screen porch,with a shed style porch roof that buts up against the wall of the house at the 1 story level--??
you don`t need a vent there if the bottom is fully open,and going to stay that way
whether the vent has shingles over it ,or not really depends on whether or not it`s an aluminum type that installs over the last shingles-with your situation,I would just close up the vent opening
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Old 02-04-2009, 06:39 AM   #6
Residential Roofer
Slyfox's Avatar
The shingle covered vent your talking about is most likely exhaust vent used to ventilate heat getting trapped in attics/crawl spaces,
if your porch is open than the venting is not needed, but if you were to enclose the porch years later it would be.
I would make sure it's installed properly and there's been no wind damage to it, but would not remove it just incase you need it in the future, it will not hurt the roof any.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 02-04-2009, 11:24 PM   #7
he`s getting water in there,No sense in replacing it for an open porch,or any unheated structure for that matter
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 02:18 PM
