How To Fix This Difficult Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-16-2011, 04:21 PM   #1
How to fix this difficult Leak
The roof is new, but the leak remains.
Any ideas?
sjadon is offline   Reply With Quote
Old 04-16-2011, 07:39 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
Is the leak inside or is the water running down the exterior wall where the rotted area is ?
How many layers ?
Can you take a close up picture of the area the red lines are pointing to ?
Roofmaster417 is offline   Reply With Quote
Old 04-17-2011, 07:19 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
The last foot or so of the roof flattens out too much to be shingled. I can't see what's been done on the roof from the photo, but there should be a membrane or metal "pan" where the roof edge, valley, and chimney flashing converge. There's a lot of water coming to that area moving pretty rapidly and then stalling out before it can leave the roof. In a hard rain, you probably have a little pond in that area.
seeyou is offline   Reply With Quote
Old 04-17-2011, 07:52 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
That whole corner should have been addressed at the time of the new roof installation.
Remove and replace the curved crown molding
I'll bet there's rot behind that.
See you is right on... a metal pan detail along with a membrane is needed.
I would also question the counter-flashing in the chimney.
Shame on the the roofer
tcleve4911 is offline   Reply With Quote
Old 04-17-2011, 08:11 AM   #5
Residential Roofer
Slyfox's Avatar
It's hard to say what's going on from those pictures.
A couple up close from different angles would help.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-18-2011, 01:16 AM   #6
Rewards Points: 1,088
To me, the only fix is a redesign of that roof section. That middle gutter has got to be the shortest horizontal length that I have ever seen.
Whoever put in those three gutters couldn't have picked a worse color with no attempt to blend in with the house.
To make it at least aesthetically appealing, I would get rid of the top of that center section (chimney?) and get rid of that curved slope and have just two normal shaped dormers with a long horizontal section in the middle.
Also, I would recommend some nice copper gutters vice those white ones.
handy man88 is offline   Reply With Quote
Old 04-18-2011, 08:08 AM   #7
Rewards Points: 2,238
@handy man88
Yes, should put some kind of "cricket/saddle" on the right side of the
chimney - copper pan?! - I&WS.
If copper is "out of the budget" - brown, gutters & downspouts? -
something, other than white. (Copper would look good!)
Looks like a "Accident waiting to happen"! Ouch!
Regards!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-18-2011, 07:09 PM   #8
Any ideas?
More pics different angle.... And pick up that hose before someone trips over it
Don Smith is offline   Reply With Quote
Old 04-18-2011, 07:22 PM   #9
Originally Posted by rossfingal View Post
@handy man88
Regards!
rossfingal
yep cricket/saddle is your best bet.....
Gizmoman is offline   Reply With Quote
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
leak leak leak dongdong1 Building & Construction 4 01-11-2011 10:21 PM
Freon Leak captainron19 HVAC 3 04-16-2010 05:30 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
