How To Fasten Downspouts - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-19-2013, 07:56 AM   #1
how to fasten downspouts
I have aluminum downspouts around my home. What's the best way of fastening them so they do not become loose because of high winds, etc...currently I have a nail going through the downspout to the gutter, but it often comes loose.
valpd is offline   Reply With Quote
Old 05-19-2013, 08:04 AM   #2
I'm referring to the part of the diagram that says "4-6 feet from house"
http://www.google.com/search?q=downs...UDElC3PPoZM%3A
Old 05-19-2013, 12:43 PM   #3
Originally Posted by TarheelTerp View Post
Downspout brackets (of one sort or another).
Like motor oil... brand and such really don't matter much IF it's there.
I was more referring to the extension.
Old 05-19-2013, 02:43 PM   #4
Rewards Points: 13,300
I've used 24" insulation ties bent to the shape of the down spout.
Old 05-19-2013, 04:11 PM   #5
I also bought a 2" blue flat / smooth hosing for my sump pump discharge pipe.
Old 05-19-2013, 04:12 PM   #6
I curved it to the left because of a been back by the spruces? Should I place one of those insulation ties on the pipe itself?
Old 05-19-2013, 05:13 PM   #7
Rewards Points: 2,238
Show us a pic of how the downspouts are attached.
rossfingal is offline   Reply With Quote
Old 05-19-2013, 05:17 PM   #8
Why? Do you have an question about something?
Old 05-19-2013, 05:26 PM   #9
Old 05-19-2013, 05:31 PM   #10
kwikfishron's Avatar
Rewards Points: 186
If that was my place I'd bury drainage pipe heading down the hill and have drain to daylight.
You have plenty of slope there, all you have to do now is dig a ditch.
kwikfishron is online now   Reply With Quote
Old 05-19-2013, 05:38 PM   #11
Can't. Spruce roots are all over.
Old 05-19-2013, 05:45 PM   #12
Rewards Points: 186
That doesn't change my answer.
The Following User Says Thank You to kwikfishron For This Useful Post:
OldNBroken (05-19-2013)
Old 05-19-2013, 05:46 PM   #13
I hear you. I guess you would have to come look in order to understand.
Old 05-19-2013, 07:45 PM   #14
My big Inverness is the downspout by our basketball in the front. The ball will constantly bang into it. Any thoughts?
Old 05-19-2013, 08:20 PM   #15
Damn autocorrect. Not Inverness, i meant "concern"
downspouts.. sh40674 Landscaping & Lawn Care 6 03-19-2013 04:53 PM
Downspouts RegLearning Roofing/Siding 2 02-26-2012 09:25 PM
Downspouts & Sump Pits claxton51 Building & Construction 2 04-06-2011 12:40 PM
Treated or untreaded 2x4 at bottom of interior walls - and how to fasten? vsheetz Building & Construction 4 02-17-2009 11:53 AM
best way to fasten backer board? ponch37300 Flooring 17 01-06-2009 01:59 PM
