How To Enclose Soffit At Gable Ends? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-05-2013, 08:15 AM   #1
Rewards Points: 113
How to enclose soffit at gable ends?
Hi folks,
I'm looking to enclose the eaves on my shed at the gable end. The eaves are 12" from the building and I have simply nailed a 2x6" to the building at the gable ends doubling as the fascia and overhang. So basically what's needed is a triangle piece cut to fit below the end fascia board. I'm not sure if this is right or how to attach it? I wasn't sure where to nail.
Thanks.
mklein49 is offline   Reply With Quote
Old 10-05-2013, 05:34 PM   #2
Rewards Points: 13,456
Post a picture to make sure any suggestions are at least in the area where your asking about.
There's lots of different ways to do it.
http://www.bing.com/images/search?q=...scia&FORM=IGRE
Old 10-06-2013, 10:27 AM   #3
Rewards Points: 113
Here a couple of photos. I had planned to make the soffit even with the ground and then needed something to enclose that end. I see there's lots of options. Any recommendations would be appreciated. Thanks a lot
Old 10-06-2013, 09:52 PM   #4
Rewards Points: 944
I've built the gable ends like that before, then clad the board and have a drip edge over it, and side up to the rake board.
I've also just ended the sheathing at the wall and used a gutter apron to hang over the siding, then vinyl side up to the roof.
I'm told that both methods will result in the edge of the roof and the top of the wall rotting out.
Time will tell. I simply don't believe that water will get through the shingles, roofing paper, and gutter apron, or through the housewrap and siding.
I do think that it looks better with a soffit, however, but I don't want to pay the extra cost of a 1' overhang.
As for how you should handle where the soffit on the eave side meets the gable, you'll want to make yourself a little box there out of plywood or 1x lumber, then clad the whole thing with coil stock/fascia cover.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
mklein49 (10-07-2013)
Old 10-07-2013, 06:29 AM   #5
Rewards Points: 22
Too late now, but you should have had the rake board run longer to cover the end grain on the fascia.
To answer your question, cut a triangle to fill in the space for the soffit. Screw the triangle up into the rake board from the bottom on the short end. One the tall end, you can face nail into the sheathing.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 10-07-2013, 07:47 AM   #6
Rewards Points: 113
Interesting on the rake board. I never thought of that until you mention it. It's pretty obvious on that photo. I do plan to cover the boards with aluminum.
Old 10-11-2013, 10:12 AM   #7
Rewards Points: 113
Question
Thanks for all advice so far. So what I'm not clear on is how to cover that section properly now with aluminum. I have the pre-bent 6" fascia cover for the rake board. But with the pre-bent piece i wont' be able to run it past the triangle that I add to cover the eaves. I'm trying to think what to do here.
I figure I could cut the short piece off the pre-bent cover for the rake board and then run it to the other fascia board and overlap the aluminum clad triangle. Alternatively, I could just stop that when I hit the triangle.
Any thoughts? Hopefully, my description is clear enough. The basic question is how the heck to do I cover the area described above properly with aluminum. Thanks.
Old 10-11-2013, 11:13 AM   #8
Rewards Points: 22
My rakes used to be covered in aluminum before I had it redone in PVC. I looked as some old pics. The rake board was done in one piece and the triangle in another.
Dan
Old 10-11-2013, 01:04 PM   #9
Rewards Points: 113
was the bottom of the rake covered with aluminum prior to nailing in the triangle pice then? Or did you just have the outside of the rake covered?
Old 10-11-2013, 01:14 PM   #10
Rewards Points: 22
I found a pic with better detail. Looks like the triangle was wrapped first, then the rake over it.
Dan
Old 10-11-2013, 01:56 PM   #11
Rewards Points: 113
Ok that's pretty much what I had in mind. I think I'll just cut of the bottom piece from the rake cover so I can overlap the rest of it over the triangle.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 09:12 AM
Older house, no soffit vents- what to do? nebben Roofing/Siding 3 01-24-2007 02:37 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
Garage w/ Gable Ends dmend Carpentry 3 04-07-2006 10:34 PM
