How Do You Flash Vents On Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-15-2010, 07:09 PM   #1
How do you flash vents on flat roof
I have several vents for a bathroom & laundry that is currently run to the side of the building and then up to the roof. This is a bit of a pet peeve because it goes through an area I'm converting to bedrooms which requires soffiting the rooms that are already really small as is.
So I am thinking about running it straight up through the roof. It is a flat roof. On a sloped roof, flashing seems pretty easy, but not sure how its done on a flat roof. Is it that much harder that the previous contractor didn't want to do?
acerunner is offline   Reply With Quote
Old 10-15-2010, 08:15 PM   #2
why not do a side wall vent instead of running it all the way up to the roof
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-15-2010, 08:42 PM   #3
as I explained, the vent has to run through a couple very small rooms. Soffiting in the room will make it feel even smaller. Just exploring my options. Is it really that hard?
Old 10-15-2010, 08:45 PM   #4
No its not hard at all for an experienced roofer.What type of roof do you have?
johnk is offline   Reply With Quote
Old 10-15-2010, 10:17 PM   #5
its a tar & gravel flat roof.
Old 10-15-2010, 10:53 PM   #6
Figure out exactlay where your hole will be,mark center by pounding a nail through from inside.Go on roof and find nail and sweep a nice area all around it,center flashing over your nail.Make a rough outline,roughly 6-8" bigger on all sides of flashing.You will need to chip rocks away from this area being careful as to not tear through layers,you only want to scrape away the top layer of asphalt that is holding the rocks.A good way to loosen the rocks is with a hammer,this will aid in scraping rocks.A paint scraper or end of hatchet should do the trick.We have a special tool,we call out here call a spud bar.Now mark out your hole,and cut out the paper with a utility knife(hole only).Center flashing on hole and nail down with roofing nails aprox 3-4 per side.Get a good fibered emulsion and spread a nice thick coat out to edge of gravel and right up and around your pipe,with a trowel.You can wait to dry and paint it or spread some gravel over the emulsion while still tacky,just make sure you have a nice thick 1/2"-3/4" and even coat before covering.I usually use mod-bit for these types of things,but this method is far more Diy friendly.
The Following User Says Thank You to johnk For This Useful Post:
acerunner (10-18-2010)
Old 10-18-2010, 08:32 PM   #7
thanks john
Old 10-19-2010, 09:36 AM   #8
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Another thing, scraping the rocks is alot easier when the roof is cool. If you're going to do this, do it first thing in the morning. After the asphalt/tar has warmed up it can become almost like trying to scrape bubble gum imbedded with rock. Not ez.
I also agree with John, mod bit is probably easier for a trained roofer but I never recommend a torch be used by a DIY'er. I personally hate tar and gravel roof repairs, unless the original roofers forgot to imbed the gravel as I sometimes see. Even as a roofer who has done numerous numerous of these repairs, I never warrant tar and gravel repairs.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Flat roof maintenance retired guy 60 Roofing/Siding 9 09-26-2009 01:44 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
