How Do I Vent Boxed Eaves???? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-26-2010, 09:46 PM   #1
Question
How do I vent Boxed Eaves????
Hey Roofing Pros,
Just bought a 1920's craftsman bungalow. I started removing the non-perforated soffit to replace with vented.
The dang eaves are closed off with boxing between the rafters. It does have a ridge vent, but without soffit vents.... this is useless.
What should I do ??
Thanks for the help.
Palmetto Moon is offline   Reply With Quote
Old 06-27-2010, 06:34 AM   #2
kwikfishron's Avatar
Rewards Points: 194
I picture would help, but if by “boxing between the rafters” you mean a 2x4 block sitting on top of the wall and between the rafters you can “usually” create the airflow you need drilling the blocks.
How much drilling, how big of holes, and is that all you need to do? Can’t really say without more info.
kwikfishron is offline   Reply With Quote
Old 06-27-2010, 07:35 PM   #3
How do I vent with boxed eaves
Hey Kwikfishron,
Thanks for the response. You are dead on.... it looks like a 2x6 between the rafters. Do you think this should only be one board thick, and I should drill with a hole saw and put in a vent?
Thanks a million.
Michael
Old 06-29-2010, 06:00 AM   #4
Rewards Points: 194
Do you think this should only be one board thick?
It should be but you never know with old houses.
You need to get up there in the attic and see for yourself.
When you’re up there, snap a couple of pictures and post them here.
The Following User Says Thank You to kwikfishron For This Useful Post:
Palmetto Moon (07-01-2010)
Old 06-29-2010, 07:14 AM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
It sounds like an open cornice that's been closed in. There's likely insulation up against the back of that board if the house has been insulated much at all. Probably, your best option is to add venting through the roof.
To answer the board thickness question, it's probably only one board thick. Could be a 1x or it could be a 2x.
seeyou is offline   Reply With Quote
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
