How Do I Tie In The Hips And Ridge Caps? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-11-2012, 09:11 PM   #1
How do I tie in the hips and ridge caps?
Does anyone have any suggestions or links on joining the ridge caps to the caps coming up from the hips on a roof? I tried doing it and they look like crap where the three lines come together. I'm using three tab shingles as the caps. I may be using the wrong terminology, so hope the attached image helps. Thanks!
emory is offline   Reply With Quote
Old 12-11-2012, 10:19 PM   #2
Rewards Points: 13,752
http://coroofs.com.au/wp-content/upl...nt-405x350.jpg
If these are architectectural shingles you should be using real hip and ridge caps not thrre tabs.
There to thin and will crack long before the shingles need replacing.
emory (12-11-2012)
Questions Regarding Ridge Beam bobber66 Building & Construction 9 10-21-2012 01:21 PM
looking for pics/vid of shingling hip to ridge transition slk Roofing/Siding 1 06-08-2012 07:32 AM
Ridge or Static Vents on Multi-level Hip Roof texasprd Roofing/Siding 16 05-27-2011 01:38 PM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 06:20 PM
First roof ... am at the hips and ridge KEITHnhia Roofing/Siding 4 06-23-2009 11:26 AM
