Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-31-2012, 06:59 PM   #1
how do I seal this roof flashing around the pipe?
I have 11 inch piping going through this 8" flashing. I tried buying 10" inch flashing but it was too big in the diameter. I had to cut alittle bit as you can tell from the picture to get the pipe through. what would would be the best thing to use this to seal this?
I already have a storm collar to put over it once it is sealed. someone suggested I just need a storm collar but The water can still get in even with a storm collar.
From the picture I haven't install it yet. It is sitting on my carpet ready to install but I need something to seal it. I was thinking of using high temperature flue tape or foil tape.
Here is a link to what i want to use
Amazon.com: 3M 2113NA High Temperature Flue Tape, 15-Foot Roll: Home Improvement
Or should I just buy foil tape? Or should I use hi temp silicone sealant? Or do you suggest something else?
guitar548 is offline   Reply With Quote
Old 09-01-2012, 10:10 AM   #2
This just stems form the "Doing it Right" attitude, but why not buy an 11" B Vent flashing, instead of jimmy-rigging an 8"?
bcdemon is offline   Reply With Quote
Old 09-01-2012, 10:26 AM   #3
What is it your trying to vent?
Just wondering because it's rare to see a vent that big.
Old 09-01-2012, 04:38 PM   #4
fireplace .
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 09-01-2012, 05:42 PM   #5
Is that single walled galvinized pipe?
Old 09-01-2012, 07:00 PM   #6
Super Moderator
You can get the correct size ---call a roofing supply company or an HVAC supply house---that larger size may not be available at a big box store.
Old 09-01-2012, 10:55 PM   #7
yeah, get the right flashing from a furnace supply, and unless water starts to go uphill-only in a hurricane will the collar let water in.
RJM Build is offline   Reply With Quote
Old 09-02-2012, 09:38 AM   #8
They don't carry the correct size. At ventingpipe.com they have at 12 inch 10 inch and 8 inch. I ordered one and had to ship it back. They don't carry 11 inch. They said they don't carry that size. Yes I had to take a 8 inch with a 10 inch diameter and cut it to make it work.
The storm collar I got fits it perfectly however I need to cover up the sides. Which I am just going to use high temperature flue tape.
Yes it is a double wall pipe.
My question is will the high temperature flue tape hold up in the outside weather?
Old 09-02-2012, 06:23 PM   #9
I am unsure of what and why you are sealing this. The vent cap you have pictured is open at the top by design. It is a way for super heated air that will surround the vent pipe in the event of a long burning fire to escape. This is to remain open and then the storm collar will sit over it like a little hat. You should not see the vents when the collar is over it, but there needs to be a way for air to escape or you risk a structure fire. just slide the storm collar over it and I usually see the fireplace guys seal the top of the storm collar with OSI. Whether OSI is the approved product for this? I dont honestly know but that is what I see a LOT of fireplace companies use-I am just a roofer.
Old 09-03-2012, 05:40 PM   #10
Pro Slate Roofer
tinner666's Avatar
Make your own storm collar if you have to. Slide it down and caulk around the storm collar.
Frank
tinner666 is offline   Reply With Quote
Old 09-05-2012, 09:48 AM   #11
you need to buy a collar for it. that should do the job.
hotrod351 is offline   Reply With Quote
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Nearly flat roof, with ventilation pipe, ice dams / leak - suggestions needed! highvoltz Roofing 6 11-02-2011 10:49 PM
moving vent pipe in roof cumak Plumbing 2 10-12-2010 11:32 PM
Need roofing tips! dc4nomore Roofing 114 07-03-2009 08:01 AM
What pipe flashing do I use on a tile roof? JDM Roofing 3 05-13-2009 07:58 PM
