-   -   how do I seal this roof flashing around the pipe? (http://www.diychatroom.com/f9/how-do-i-seal-roof-flashing-around-pipe-155436/)
guitar548 08-31-2012 05:59 PM
1 Attachment(s)
I have 11 inch piping going through this 8" flashing. I tried buying 10" inch flashing but it was too big in the diameter. I had to cut alittle bit as you can tell from the picture to get the pipe through. what would would be the best thing to use this to seal this?
I already have a storm collar to put over it once it is sealed. someone suggested I just need a storm collar but The water can still get in even with a storm collar.
From the picture I haven't install it yet. It is sitting on my carpet ready to install but I need something to seal it. I was thinking of using high temperature flue tape or foil tape.
Here is a link to what i want to use
Amazon.com: 3M 2113NA High Temperature Flue Tape, 15-Foot Roll: Home Improvement
Or should I just buy foil tape? Or should I use hi temp silicone sealant? Or do you suggest something else?
bcdemon 09-01-2012 09:10 AM
This just stems form the "Doing it Right" attitude, but why not buy an 11" B Vent flashing, instead of jimmy-rigging an 8"?
joecaption 09-01-2012 09:26 AM
What is it your trying to vent?
Just wondering because it's rare to see a vent that big.
Fix'n it 09-01-2012 03:38 PM
fireplace .
joecaption 09-01-2012 04:42 PM
Is that single walled galvinized pipe?
oh'mike 09-01-2012 06:00 PM
You can get the correct size ---call a roofing supply company or an HVAC supply house---that larger size may not be available at a big box store.
RJM Build 09-01-2012 09:55 PM
yeah, get the right flashing from a furnace supply, and unless water starts to go uphill-only in a hurricane will the collar let water in.
guitar548 09-02-2012 08:38 AM
They don't carry the correct size. At ventingpipe.com they have at 12 inch 10 inch and 8 inch. I ordered one and had to ship it back. They don't carry 11 inch. They said they don't carry that size. Yes I had to take a 8 inch with a 10 inch diameter and cut it to make it work.
The storm collar I got fits it perfectly however I need to cover up the sides. Which I am just going to use high temperature flue tape.
Yes it is a double wall pipe.
My question is will the high temperature flue tape hold up in the outside weather?
RJM Build 09-02-2012 05:23 PM
I am unsure of what and why you are sealing this. The vent cap you have pictured is open at the top by design. It is a way for super heated air that will surround the vent pipe in the event of a long burning fire to escape. This is to remain open and then the storm collar will sit over it like a little hat. You should not see the vents when the collar is over it, but there needs to be a way for air to escape or you risk a structure fire. just slide the storm collar over it and I usually see the fireplace guys seal the top of the storm collar with OSI. Whether OSI is the approved product for this? I dont honestly know but that is what I see a LOT of fireplace companies use-I am just a roofer.
tinner666 09-03-2012 04:40 PM
Make your own storm collar if you have to. Slide it down and caulk around the storm collar.
hotrod351 09-05-2012 08:48 AM
you need to buy a collar for it. that should do the job.
