-   -   How do I fix this?! (pic included) (http://www.diychatroom.com/f9/how-do-i-fix-pic-included-72845/)
JakAHearts 06-04-2010 06:28 PM
I recently discovered a leak in my roof and am 99% sure if not 100% that this is the cause. The flashing is lifted up all along my edge here. Im planning on getting a new roof next spring so is there a decent temporary repair for it? Here is a shot and a close up.
http://i104.photobucket.com/albums/m...6/DSCN6204.jpg
http://i104.photobucket.com/albums/m...6/DSCN6205.jpg
Thanks everyone!
Shane
Ed the Roofer 06-04-2010 06:46 PM
Those step flashings are probably nailed into the wall instead of originally into the deck, probably because the last tear-off job removed multiple layers and they were at a higher elevation due to the thickness.
They look too banged up to be efficient, but they should have been shingled over the top of them with each course of shingles.
Temporarily, you can apply a caulking sealant under them at the junction where the shingles abutt the wall and try to seal the gap that should be present there.
Ed
DangerMouse 06-04-2010 06:49 PM
That CAN'T be romex I'm seeing there....
I'd clean out the crack, tap down as much as possible with a hammer and roofing tar the crap out of it until you can fix it correctly.
Shove as much inside the gaps as you can. It's messy, but what do you care, right? Po)
DM
JakAHearts 06-04-2010 06:56 PM
Mr Mouse. What makes you think that isnt Romex you are seeing there? Anyway, should I try to nail it back down on top of some sealant and then roof tar the seam. Seems that should hold up pretty darn well. Thanks for the quick responses!
Shane
Scuba_Dave 06-04-2010 07:28 PM
Romex isn't rated for outside use like that
Is that an AC line also - insulated ?
I'd try to seal it as Ed said
JakAHearts 06-04-2010 09:10 PM
HAHA I knew that the wiring wasnt acceptable. And yes, that is an A/C line insulated. Is that also a no no? If I should/need to move the wire, now would be a good time as it wouldnt be the hard thing since all the walls and ceilings are open. Whats a proper way to run a line outside that way or is there no proper way? What about the A/C line, does that need moved/changed as well? Thanks so much, you guys are the best.
Shane
Scuba_Dave 06-04-2010 09:33 PM
I'd run the romex inside a wall since you said its open
Outside you can run UF wire, or THWN in conduit
Not sure on the AC line
seeyou 06-05-2010 04:45 AM
Shane
The A/C line set can be run inside as well, but outside is acceptable. If there's enough slack,try to move it up on the wall and attach it so the flashing can be accessed w/o disturbing it later.
edit: looks like the insulation on the line set is in poor condition. Might be worth replacing it.
Ron Smith Const 06-05-2010 07:02 AM
If it were me.I'd clean it up a bit get all the old built up crap off the flashing.Clean all the old tar off the under side of the edge of the flash.Apply a thick bead of tube tar under the flash and then nail the flash back down to the roof.Like Ed stated the flash in installed incorrectly.And the wrong material was used.The wall should be individually steped with flash.
kwikfishron 06-05-2010 07:16 AM
199 Attachment(s)
Looks like a leak to me.
If you want to be 100% sure before throwing gallons of goop on it get up there with a hose.
Start at the bottom and “slowly” work your way up with someone looking on the inside, you'll find your leak.
If you get up there and clean it all up and start nailing down the probably very fragile old metal to the roof you could make things worse. Use a little TLC.
JakAHearts 06-05-2010 08:29 AM
Is there some trick besides elbow grease to cleaning the old black goop off. It seems to be rather permanent. :D
kwikfishron 06-05-2010 08:55 AM
199 Attachment(s)
Elbow grease is about it.
Ron Smith Const 06-05-2010 11:33 AM
The only tool is a flat bar.I would never recommend chemicals on a shingle roof.Work on it in the morning when it is cold or cool.
Ron Smith Const 06-05-2010 11:42 AM
Im not so sure the metal is nailed to the wall.The lack of J channel and the Face nails in the siding are a tale-tell sign that the metal is basically just slide in behind the siding.Not to mention they bent a few peices of siding in the process.
JakAHearts 06-13-2010 03:54 PM
I just wanted to say thanks to everyone in here. I reflashed and tarred the leaking area and replaced the romex with approved outdoor 10-2 wiring. Thanks so much to everyone here for keeping me and my family safe and dry!
