How Do I Avoid Cutting Rafters When Cutting A Ridge Vent Channel? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2011, 09:44 AM   #1
kmc
How do I avoid cutting rafters when cutting a ridge vent channel?
I will cut the vent channel with a circular saw and either a plywood blade or a carbide blade. I intend to set the height of cut to the thickness of the plywood. Should I care if it slices the rafters during this process? Is there a safeguard to this?
kmc is offline   Reply With Quote
Old 05-26-2011, 09:46 AM   #2
Framing Contractor
Rewards Points: 120
Set the height on the saw and make the cut. Obviously, you don't want to cut any deeper than necessary. If you leave a small kerf in a rafter, it is no big deal.
sixeightten is offline   Reply With Quote
Old 05-26-2011, 09:49 AM   #3
kmc
thanks for that quick answer.
Old 05-26-2011, 09:50 AM   #4
Framing Contractor
Rewards Points: 120
You might want to use an old blade. Many times there will be nails that you don't see.
Old 05-26-2011, 09:55 AM   #5
kmc
That's one reason why I might use the carbide blade. New saw. Maybe I'll just pick the cheapest one for this.
Ridge Vent and Power Vent? etern33 Roofing/Siding 7 06-06-2011 07:06 AM
ridge vent ugabulldog Roofing/Siding 4 09-28-2010 08:59 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 04:59 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
