11-02-2011, 08:25 PM
#1
How To Distinguish Between Felt Weight
Hi There,
I'm in a situation where I need to figure out what weight of felt was used when the roof was installed. Any help is greatly appreciated!
Thanks in advance,
Rickey
11-02-2011, 08:28 PM
#2
Framing Contractor
Why the issue?
Lift up an edge and check.
11-02-2011, 08:38 PM
#3
Originally Posted by sixeightten
Why the issue?
Our roof inspector noted that there is only 1 layer of felt when there should be 2 and is recommending a new roof when the current one is only 9 years old and has a life span of 25. My buyers are getting spooked, thus I need to figure out the weight and if it meets local standards.
So it's just printed on the material?
Thanks Sixeightten!
11-02-2011, 09:10 PM
#4
Framing Contractor
It wont be printed. A roofer can tell the weight by feeling the thickness. The #30 is twice as thick as the #15.
The Following User Says Thank You to sixeightten For This Useful Post:
11-02-2011, 09:18 PM
#5
Makes no sense. Where does it say there should be two layers of felt? Get a real inspector!
11-02-2011, 09:54 PM
#6
Moderator
A 2/12 up to 4/12 require two layers per IRC, though CA is usually way stricter on most everything.
Did you ask your local Building Department yet?
Gary
Clothes taking longer to dry?
11-02-2011, 09:57 PM
#7
Gary
Where was it said that it was less than a 4 pitch?
11-02-2011, 10:30 PM
#8
Moderator
"Where does it say there should be two layers of felt?"----- it was your question.
RR- start reading about felts/papers and their weights on page #4, here: http://www.dickseibert.com/martin.pdf
Gary
11-02-2011, 10:35 PM
#9
Gary
I'm talking about in the original post. No where does the OP mention the pitch of their roof.
Maybe I worded my question wrong to the point it would only make sense to me.
Why does the inspector think there are two layers of felt needed? Most inspectors I've met have no knowledge of roofing.
11-03-2011, 06:21 AM
#10
KemoSabe
Originally Posted by RealtorRickey
Hi There,
Thanks in advance,
Rickey
Just go to the local home center and feel for yourself. That's the best way to know what you're dealing with.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
The Following User Says Thank You to loneframer For This Useful Post:
11-03-2011, 03:41 PM
#11
Shut in w/o Home
I tried that and I'm no longer allowed in Home Depot. Wasn't sure if the clerk was a girl or a boy............
11-03-2011, 03:52 PM
#12
Shut in w/o Home
Gary
It's not just 2 layers. They are to be half lapped. So, in this case, one layer of #30 does not equal 2 layers of #15.
11-03-2011, 04:04 PM
#13
Or is he talking about the eaves? Two layers of 15# felt with roofing cement between them is acceptable instead of I&W.
The Following User Says Thank You to MJW For This Useful Post:
11-03-2011, 06:27 PM
#14
KemoSabe
That's a different kind of "felt" my friend.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
