How To Determine If OSB Decking Should Be Replaced - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-09-2012, 08:55 AM   #1
Checking things out
How to determine if OSB decking should be replaced
After having a "professional" install a replacement roof a year ago, I'm in the process of removing what was installed a section at a time and installing a proper replacement roof. By the crew chief's own admission, they simply installed new shingles over rotten decking in several places, something I intend to correct.
I'm looking for some advice on determining which OSB decking boards should be replaced. Obviously rotten (buckling and/or deteriorated) boards are a no-brainer, but what about less-obvious damage? I have read that OSB is very vulnerable to warping from moisture and I've found a few spots where the edges of the boards seem to be bulging out some, but these boards don't seem structurally unsound when pushing on them in several spots.
Any advice? Thanks!
-Mason
masonbrown is offline   Reply With Quote
Old 10-09-2012, 09:14 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
If there is edge creep or deflection in the panel, replace it.
Old 10-09-2012, 09:18 AM   #3
Rewards Points: 13,260
If there turning black that's mold and they have to go.
Where are you looking for signs of damage?
Windows on Wash (10-09-2012)
Old 10-09-2012, 12:05 PM   #4
Checking things out
On this particular section (above the garage door) the bottom of the boards isn't accessible from the attic so I'm looking exclusively at the top (after having removed all the underlayment, nails, etc) so far. I'm attaching a couple of photos to show what I'm dealing with, hopefully that helps clarify things.
Thanks for the replies...
-Mason
How to determine if OSB decking should be replaced-image-2806370304.jpg   How to determine if OSB decking should be replaced-image-318954123.jpg
Old 10-09-2012, 12:17 PM   #5
I'm not seeing any rot in those pictures. The black just looks like old tar paper smuges.
Old 10-09-2012, 02:01 PM   #6
Don't see anything wrong there either.
Old 10-09-2012, 05:01 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
me either
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-09-2012, 08:01 PM   #8
Davejss's Avatar
Rewards Points: 740
Looks fine.
Davejss is offline   Reply With Quote
Old 10-09-2012, 08:26 PM   #9
I'm not in love with the way it was flashed at the wall, if it was going to fail anyplace that's where it would be.
How did you happen to be talking to the lead man and find out about roofing over the rotten wood?
Any chance he's not working for that company anymore and is trying to cause trouble?
Old 10-09-2012, 09:41 PM   #10
ParagonEx's Avatar
Rewards Points: 150
Looks normal.
The flashing was most likely what the roofers had to work with because it was already there unless you paid them to replace it.
ParagonEx is offline   Reply With Quote
Old 10-09-2012, 11:21 PM   #11
RFN-4A-LVN
Roofmaster417's Avatar
I have seen some of that black on roofs that were installed without felt.I see only one spot that looks a bit off color but I see nothing that leads me to believe they simply roofed over "Rotted" decking.
How was it determined that they roofed over rotted O.S.B ? How did you come to this conclusion ? Did you notice something within the attic on this section ?
The apron (flashing) could have been salvaged and had minimal damage had the roofers used a pry bar to loosen the fasteners over and under the apron instead of a tear off spade.That just bugs the heck outta me when people don't use pry bars when pulling step flashing from walls,skylights,chimneys and when cleaning aprons.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
mae-ling (10-09-2012)
Old 10-09-2012, 11:58 PM   #12
RFN-4A-LVN
Old 10-22-2012, 03:04 PM   #13
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
If it's OSB it should all be repalced
But seriously if it's stained, if it swollen, if it is soft, spongy, can;t hold a nail; it should be replaced. I prefer CDX as a roof sheathing, I see no benefit other than low price to using OSB.
The pics you are showing look ok for sheathing. There is a little bit of potential rott in the first pic bottom right hand corner.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 10-23-2012, 12:30 PM   #14
Rewards Points: 43
The black holes rotted thru the OSB in the second pic dont bother you?
Al
AlleyG is offline   Reply With Quote
Old 10-23-2012, 01:41 PM   #15
Grumpy's Avatar
Al
What holes? I double checked and even enlarged. I don't see any holes in either pic.
-Grumpy
Decking Issue after new roof install CrankyDragon Roofing/Siding 12 07-04-2011 11:26 AM
contactor chattering, replaced it- still have chatter sprinkle100 HVAC 7 10-27-2010 06:10 PM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 2 10-19-2010 08:54 PM
ribbed steel decking chaos232 Building & Construction 3 06-16-2010 06:15 AM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 07:16 PM
