How To Close Gaps Between Roof And Soffit? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-27-2010, 10:54 PM   #1
I have one area along my roofline where the plywood is slightly warped therefore no longer even with the overhang/soffit area. Another two or three small areas where shingles just don't lay even and a small hole (about 2-3") that allows things to crawl into my attic.
I really need to reroof but waiting one more hurricane season to see what happens. BUT in the meantime I want to close these gaps. I had a squirrel or something get in during the winter and the occasional wood roach drops from the overhanging trees and finds it way in presumably through these gaps.
Steel wool? Any other ideas? Thanks
By the way, I just want to close these up for now. I can walk (or crawl) all around my attic and have not yet (knock on wood) seen any evidence of actual water damage..
snosurfa7 is offline   Reply With Quote
Old 06-04-2010, 03:34 PM   #2
Can you use some metal screening (thinking hardware cloth) and expanding foam?
posylane is offline   Reply With Quote
Old 06-04-2010, 06:43 PM   #3
Spray Great Stuff expanding foam into the gaps and allow to dry for a day and then use an abrasive sanding sponge to smooth it out and surface skim coat the exterior with a colored caulk, Vulkem from Tremco works good, with a matching color to the shingles or gutters.
I have repaired 1-2 foot diameter squirrel holes in wooden soffits that way with an additional backing for support.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-04-2010, 08:00 PM   #4
Registered User
Rewards Points: 526
I'd hate to run into those squirrels in the attic!!! 2' diameter holes ............ Keep in mind rodents and bugs love the spray foam...... 1/4" hardware cloth as mentioned.
Be safe, Gary
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
hip roof ventilation lib123 Roofing/Siding 1 08-08-2008 03:21 PM
Older house, no soffit vents- what to do? nebben Roofing/Siding 3 01-24-2007 02:37 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
