How To Clean A Copper Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-23-2012, 12:52 PM   #1
How to clean a copper roof
How do you clean/restore a badly bird dropping stained copper roof over a bay window?
Nailed is offline   Reply With Quote
Old 09-23-2012, 02:53 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Soap, water, stiff bristle brush. Do not use wire brush. Spray nozzle on garden hose or extreme low pressure on power washer. Spray from topside down.
There are commercial and homemade products, but many wiill change patina of copper, often not to the best. But if you have chemical stain from droppings, it may not matter. Weak acids such as white vinegar or slightly stronger 10% horticultural vinegar, wear rubber gloves, protective clothing and eye protection. Extreme case may need soda, or soft pellet blasting, not sand blasting.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
very difficult house to vent roof help please marlowe Roofing/Siding 7 09-10-2011 12:57 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
