How To Cap / Wrap Aluminum Around A 4x4 Post - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-28-2016, 11:10 AM   #1
From Philadelphia
Rewards Points: 275
How to cap / wrap aluminum around a 4x4 post
What is the best way to cap/wrap aluminum around a 4x4 post? I'm assuming this can't be done with just one piece of aluminum, but will need two.
Suggestions?
hellohello is offline   Reply With Quote
Old 03-28-2016, 02:26 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Re: How to cap / wrap aluminum around a 4x4 post
2 pieces and put your seams to the least visible surface.
Do you have brake skills?
Old 03-28-2016, 02:57 PM   #3
From Philadelphia
Rewards Points: 275
And I assume I should hem the two rough edges of the second piece?
Old 03-28-2016, 04:54 PM   #4
Rewards Points: 726
Is the post exposed on top?
The best that I ever was able to do was form the coil stock into a square tube, slide it down over the 4X4 and put the single seam on the least visible side.
Depending on how the post is usually viewed then I put the seams away from the viewing direction.
ED
de-nagorg is online now   Reply With Quote
Old 03-28-2016, 05:39 PM   #5
From Philadelphia
Rewards Points: 275
Ahhh, I should have mentioned in my original post that the posts are already in place on a front porch, so the bottom is attached to the ground and a beam then roof sits on the top of the posts. So unfortunately there is no way to slide it down over the 4x4 :-/
The Following User Says Thank You to hellohello For This Useful Post:
de-nagorg (03-28-2016)
Old 03-28-2016, 07:24 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Not aluminum but this is how I installed a vinyl post wrap on a porch post. Ripped down the middle of one side on my table saw. Forced the post cover open and around the porch post. Closed the seam with a strip of vinyl lattice secured with white aluminum screws.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 03-28-2016, 09:06 PM   #7
Rewards Points: 854
The also make porch post wraps that work quite well.
Easy and sectionally put together.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 03-29-2016, 08:58 AM   #8
Rewards Points: 12,808
If these are pressure treated post then forget about using aluminum to wrap them.
Even the box it comes in says not to do it.
Pressure treated is treated with copper and in a few years the finish will bubble up on the coil stock.
Lot's of company's sell snap on post wraps, not cheap but will hold up and look a whole lot better.
rjniles (03-29-2016)
Round metal lamp post DJM1955 General DIY Discussions 11 08-27-2012 03:32 PM
Best way to wrap porch beam in aluminum timw88 Building & Construction 6 06-12-2009 11:05 AM
Why is my aluminum wrap around my windows pulling away? Kl483@yahoo.com General DIY Discussions 5 04-21-2009 06:04 AM
