How Can I Stop Leaks On Porch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2012, 11:03 PM   #1
Post
How can I stop leaks on porch
I am totally frustrated trying to find leaks on my back porch. I have re-shingled the roof for the 4th time only to find out after todays rain that I have more leaks than before (grrr). I feel so overwhelm that I just want to apply some tarp or any kind of sealant over the shingles to stop the leaks.
So, can anyone recommend a good sealer that I can used or tell me if I can use 201 Henry Tarp?, or what can I do in order to stop those leaks.
Pau-Latina is offline   Reply With Quote
Old 06-10-2012, 11:36 PM   #2
I know alittle about alot
JWilliams850's Avatar
whats the pitch of your back porch?
JWilliams850 is offline   Reply With Quote
Old 06-11-2012, 12:15 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Shingles aren't the answer. Neither is a tarp, nor ANY type of sealant.
Get some SBS modified roofing from your supplier and the instructions. You must use the nailable base, the inter-ply, and the cap sheet. Simple fix. Don't forget to remove shingles as necessary where it joins the house nad reinstall after you run the SBS 3' up the house roof.
tinner666 is offline   Reply With Quote
Old 06-12-2012, 06:32 PM   #4
JWILLIAMS850- I think is between 15 or 29 degrees
Old 06-12-2012, 06:39 PM   #5
TINNER666- SBS modifying roofing is the same thing as flashing??? Also what you mean by inter-ply and cap sheet
Old 06-12-2012, 06:43 PM   #6
Rewards Points: 14,312
Just post a picture,
Is it a shed style roof attached to the house at the fashia?
Old 06-12-2012, 07:25 PM   #7
Pro Slate Roofer
tinner666's Avatar
SBS is the roofing material for flat or lo-slope roofs. If shingles aren't working, they must NOT belong there. SBS sounds like the correct fit.
Just two brands.
http://www.specjm.com/commercial/roofing/sbsbituminous.asp
http://www.firestonebpco.com/roofing/asphalt/sbs/
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 08:30 PM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 06:19 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Porch roof tie in question dabensys Carpentry 6 08-11-2008 02:46 PM
