-   -   How can I remove my gutter / apron with out pulling the first row of shingels (http://www.diychatroom.com/f9/how-can-i-remove-my-gutter-apron-out-pulling-first-row-shingels-23049/)
wamyers92 07-01-2008 11:49 AM
I am trying to replace a section of gutter on the side of my office , standard 6/12 pitch with shingels and I went to remove the gutter to find out they are one piece with about a 4 inch or so gutter apron attached under the Ice and water barrier and shingels is there an easier way to remove this.. I thought about scoring the apron and trying to reuse the parts as a drip edge? will this work or should I do it the hard way and remove it all.
parkerfairfield 07-02-2008 02:38 AM
1 Attachment(s)
Some comments/questions:
Where in the world are you?
You're using terminology that I don't recognize.
What's an apron?
Advice:
You wanna replace your gutter? The EASIEST way is
FIRST to figure out if your gutter is wingless, or has a wing.
If it is wingless, then you can tear off the gutter pretty easily.
I imagine it's got a wing... then you need a sawzall ... and cut off the gutter from the piece that is acting as the 'flashing' - which is the piece on your roof and the piece that then drops into the gutter.
Comments?
Ed the Roofer 07-02-2008 02:48 AM
Since you seem to have a gutter with a built in flange, apron, so to speak, and it is covered with the ice and water shield and shingles, you may want to consider a small saw with a metal cutting blade, so as not to distrupt the shingles edges extending directly above the flange of the gutter.
Parker,
A Gutter Apron is the Drip Edge Flashing, which would be a separate piece going approximately 3" under the shingles and about 3" down into the trough of the gutter. It is probably just called something different in California.
Ed
parkerfairfield 07-02-2008 03:10 AM
Parker,
Ed
Ed,
Thanks.
You're right ... in California contractors call flashing flashing (not an apron). Another difference is that due to the easy weather here flashing only goes up 1 1/2 inches under shingles, and down into the gutter 1 1/2 inches.
