How Can I Install A Soffit?? Pics Attached - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-02-2008, 11:41 AM   #1
How can I install a Soffit?? pics attached
take a look at these pictures and let me knopw what you'd reccomend!
Our overhand in the front and back of the house are covered in wood.
the inside of the attic where the over hang would me,i'm not sure where to start really.
How can I install a Soffit?? pics attached-front-house.jpg   How can I install a Soffit?? pics attached-inside-attic-copy.jpg
Hammiamm is offline   Reply With Quote
Old 12-02-2008, 11:44 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'm lost. You have a soffit. What is it that you want to do?
Soffit: http://en.wikipedia.org/wiki/Soffit
Are you asking about installing soffit venting?
- Build Well -
Old 12-02-2008, 11:48 AM   #3
I have a soffit?? the guy at the hardware store showed me a piece of metal with holes in it, or a vent that is placed in the overhang. sorry I obviously don't know much about this, how does the cool air get it, if its comp[letely closed off on the outside?
Old 12-02-2008, 11:54 AM   #4
Ok, you are asking about installing soffit venting. Do you have a ridge vent, gable vents, or attic/roof vents? You need one of these to work in conjunction with soffit venting.
Link: http://dspinspections.com/atticventing.htm
Here are some helpful links, in regards to installing soffit vents:
http://www.cornerhardware.com/howto/ht076.html
http://www.easy2diy.com/cm/easy/diy_...ge_id=35720174
- Build Well -
Old 12-02-2008, 12:00 PM   #5
I know for sure I have 4 roof vents
Old 12-02-2008, 12:02 PM   #6
I am just wondering in the picture is posted of the attic, what is that wood block??
and should I take all the insulation of of tha area?
Old 12-04-2008, 10:05 AM   #7
747
registered
747's Avatar
Rewards Points: 534
That one wood block is what the roof rafters are attached to. Unless there is another one on the other side of that arrow i don't see. If there is its probably something for cosmetic trim work. Technically the correct thing to do would be to run the plastic shoots between those rafters. But i personally have never seen ones that wide. YOu have alot of width between those rafters. Finally you do have soffits nice looking ones. Kind of like a colorado house around a ski resort. But the metal ones spaced so many feet would be the way to go. You would just cut out a square in the soffits so many feet apart and nail over with the metal soffit vent.
747 is offline   Reply With Quote
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 06:26 PM
Beefing up these columns (pics attached) joeyboy Building & Construction 9 06-25-2007 09:46 PM
I need to enclose my Loft. Looking for your opinion what I should do. Pics attached TheLoft Carpentry 3 04-23-2007 02:44 PM
Water lines on sloped ceiling (pics attached) Mr. Michael Roofing/Siding 8 03-27-2007 03:13 PM
Need help please asap...patching plaster pics attached mood Building & Construction 2 07-30-2005 11:06 PM
