How To Best Seal An Opening On The Inside Of The Drip Edge Where The Wall Is? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-11-2012, 11:26 AM   #1
Rewards Points: 1,600
How to best seal an opening on the inside of the drip edge where the wall is?
In trying to locate a roof leak, I found an opening I need to seal off. I shot some water from a garden hose to it and water dripped from the T&G ceiling inside.
It's easier to show with a picture. Look at the part I circled.
Zoomed in.
Closer.
This is about 20" long 3/4" wide?
How should I seal this off? Being a corner connection I need something flexible right?
Should I use some acrylic wood filler to patch the underside wood piece until the joint is small enough to caulk over?
Or should I just spray in some expansive foam into the crack and be done with it?
Or some other way?
miamicuse is online now   Reply With Quote
Old 11-11-2012, 07:48 PM   #2
Metal Roofing
Rewards Points: 600
This should be sealed, but its not your roof leak.
Most builders dont give a crap about that area, they assume no one see it so the stucco is usually unfinished. I see this all the time when reroofing, they do half a$$ stucco, siding, or trim because you cant see it from the ground.
AndyWRS is offline   Reply With Quote
Old 11-12-2012, 07:34 AM   #3
Yes it is not a leak but I am thinking being in Miami when I have a hurricane and driving rain some might get on the underside so I would like to seal it off.
Doesn't have to be pretty but looking for the best way to do it.
Old 11-12-2012, 07:40 AM   #4
kwikfishron's Avatar
Rewards Points: 172
Probably the easiest way to deal with that would be to knock down the high spots of the stucco, install a trim board, caulk and paint it.
kwikfishron is online now   Reply With Quote
Adding drip edge to low-pitch patio roof Joboo Roofing/Siding 13 08-07-2016 08:35 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 10:28 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
Drip edge mattflytx Roofing/Siding 3 09-09-2007 11:53 PM
