-   -   How to best seal an opening on the inside of the drip edge where the wall is? (http://www.diychatroom.com/f9/how-best-seal-opening-inside-drip-edge-where-wall-162935/)
miamicuse 11-11-2012 10:26 AM
3 Attachment(s)
In trying to locate a roof leak, I found an opening I need to seal off. I shot some water from a garden hose to it and water dripped from the T&G ceiling inside.
It's easier to show with a picture. Look at the part I circled.
http://i173.photobucket.com/albums/w...r/P1040024.jpg
Zoomed in.
http://i173.photobucket.com/albums/w...r/P1040025.jpg
Closer.
http://i173.photobucket.com/albums/w...r/P1040026.jpg
This is about 20" long 3/4" wide?
How should I seal this off? Being a corner connection I need something flexible right?
Should I use some acrylic wood filler to patch the underside wood piece until the joint is small enough to caulk over?
Or should I just spray in some expansive foam into the crack and be done with it?
Or some other way?
AndyWRS 11-11-2012 06:48 PM
This should be sealed, but its not your roof leak.
Most builders dont give a crap about that area, they assume no one see it so the stucco is usually unfinished. I see this all the time when reroofing, they do half a$$ stucco, siding, or trim because you cant see it from the ground.
miamicuse 11-12-2012 06:34 AM
3 Attachment(s)
Yes it is not a leak but I am thinking being in Miami when I have a hurricane and driving rain some might get on the underside so I would like to seal it off.
Doesn't have to be pretty but looking for the best way to do it.
kwikfishron 11-12-2012 06:40 AM
199 Attachment(s)
Probably the easiest way to deal with that would be to knock down the high spots of the stucco, install a trim board, caulk and paint it.
