How Bad Is The Leak? Possible DIY? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2013, 04:48 PM   #1
How bad is the leak? Possible DIY?
Hi everyone,
I noticed my roof is leaking a bit over the backyard patio. It seems to be seeping through and pooling over the plastic covers over the patio. How bad is the damage? I would like to try to fix it myself if it is easy. How do I do it myself? The singles are present where the leak is happening.
usafstud is offline   Reply With Quote
Old 03-15-2013, 04:56 PM   #2
Doing This Way Too Long
Rewards Points: 532
Based on those pictures the leak should be fairly localized to that area. Really need to see what that area of your roof looks like from the outside before any proper assessment can be made. Any penetrations or transistions in or above that area? That's usually the first place to start.
OldNBroken is offline   Reply With Quote
Old 03-15-2013, 05:30 PM   #3
OP updated with exterior pics
Old 03-15-2013, 07:19 PM   #4
Rewards Points: 14,306
Time for a new roof.
See how there curling up on the outside edges of the tabs?
Old 03-16-2013, 01:57 AM   #5
Rewards Points: 532
Is this in the vicinity of that rafter?
Old 03-16-2013, 02:00 AM   #6
I think so. I can take a better look tomorrow.
Old 03-16-2013, 06:59 AM   #7
Roofmaster
Rewards Points: 2,210
ONB Thats funny as heck, I just did the same thing. Nail pop. Second key to the right of the B vent. There are probably a lot more of them up there judging by the lifting tabs.
Old 03-16-2013, 07:24 AM   #8
Rewards Points: 2,516
Could you at least edit one of your outside photos and either circle or point to the area of the roof affected. Its not that dofficult. Pick a color and pick a shape.
hammerlane is offline   Reply With Quote
Old 03-16-2013, 07:28 AM   #9
Also how you post the photos can be deceiving the way they run together. when I saw this shot I was thinkng nice, a ceiling fan over the roof.
Nice catch on that nail pop to oldnbroken and jagans
Old 03-17-2013, 11:26 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
You can fix that leak pretty simply but be prepared for a bunch more. Roof is on its last legs.
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 01:26 PM
