How Bad Is This? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-28-2013, 05:29 PM   #1
How bad is this?
My roof has a double valley. House was originally u-shaped and an addition was put in the middle. So now it has two valleys that holds some water. It apparently does shed water enough or else my roof would leak?
The house is 40 years old and the addition is 25. It doesn't appear to leak.
Just wondering how normal this is and if.i should be concerned?
harlan07 is offline   Reply With Quote
Old 02-28-2013, 05:30 PM   #2
I can't tell how far up the rubber membrane goes , I guess that keeps it from leaking but what if water goes up above it?
Old 02-28-2013, 05:39 PM   #3
Rewards Points: 13,274
Poor design, it's called a dead valley. As long as that membrane does not leak it will be fine.
At some point it will fail.
Even a tapered valley so the water will run off and not just sit there would be better if at all possible.
Old 02-28-2013, 08:12 PM   #4
Metal Roofing
Rewards Points: 600
I agree with Joe.
If that does leak, it will be a huge mess. Make sure to inspect it a couple times a year, you will want to replace it before it fails.
AndyWRS is offline   Reply With Quote
Old 02-28-2013, 08:16 PM   #5
Great place to bred mosquitos.
Old 02-28-2013, 08:35 PM   #6
thanks
thanks for the replies guys.
when i inspect up there what should i look for besides places where it is dry rotting or separating from the shingles/decking?
Old 02-28-2013, 09:10 PM   #7
Roofmaster
Rewards Points: 2,172
Yeah Breed too. Unless they are all past tense mosquitoes.
Idiotic design. Maybe down the road you can extend the chimney and the outer slopes up to a common ridge. As Joe has asked a million times, where are you located???
The entire area from ridge to ridge should have been roofed with fully adhered EPDM
