Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-26-2007, 11:24 AM   #1
How to attach Roof Sheathing?
What size and type of screws are best to attach plywood over roof rafters?
sandyman720 is offline   Reply With Quote
Old 07-26-2007, 11:56 AM   #2
8d ring shank nails 2 1/2in. Nail the plywood 6in OC on the edges and 12in OC in the fields.
Malcolm is offline   Reply With Quote
Old 07-26-2007, 02:32 PM   #3
Can screws be used?
Old 07-26-2007, 04:07 PM   #4
If they are galvanized then yes, but expect to pay A LOT for screws.
Just a rough estimate, but galvanized screws at $6 a box (1 lb or 50 or so screws). Figure on putting at somewhere around 20 in each piece. So for every sheet you put down you are spending around $10 just on screws.
Honestly, thinking of the time it takes to put a scew on a drill and get it screwed in, I think it would take longer to screw than to nail. We used a nail gun with 7d nails. Even 8d will drive in with a couple good wacks.
cibula11 is offline   Reply With Quote
Old 07-26-2007, 05:21 PM   #5
I would definitely invest in a nail gun if you are replacing all the sheathing on the roof. You'll thank yourself later. I purchased a Dewalt framing nailer for $139.00 at Lowes. They came out with a new model, so I bought the one off the floor. Otherwise, they will only run you around $259.
Old 08-01-2007, 10:16 PM   #6
the roofing god's Avatar
Send a message via MSN to the roofing god
nails should be used as suggested,screws do not have anywhere near the "shear" strentgh of nails,I would put 6"nail spacing on all the rafters
the roofing god is offline   Reply With Quote
Old 08-16-2007, 09:26 PM   #7
I have gas!
Clutchcargo's Avatar
Fema recommends screws in high wind areas. I wouldn't think shear strength would matter much for roof sheathing.
www.fema.gov/pdf/rebuild/mat/fema499/hgcc_fact18.pdf
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-16-2007, 10:15 PM   #8
General Contractor
joasis's Avatar
I live in tornado alley, and FEMA has a lot of ideas about things here also. If you want to screw the decking down, by all means, get after it....my first thought was why would you want to? If high winds are a real concern, use screws at the eaves and gables,,,nail the rest. When roof fails, it is "peeled" up, and this, must fail on an edge. What typically happens is the decking doesn't fail, the rafters fail and the decking takes the entire structure with it.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 08-16-2007, 11:13 PM   #9
I also use ring shank nails on all my sheathing,which gives it shear strength & any ,if not more strength holding down than screws,meets DADE county specs,you would go to great expense to match the strength w/galvanised decking screws in comparison,and I think the screws would back up before the ring shank 8d nails ever will---you guys never have a tree hit the house???that`s where shear strength comes into play
Uneven sheathing on new construction roof mjw930 Roofing 28 04-10-2007 10:51 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
roof sheathing placement dmend Roofing 1 03-20-2006 10:03 PM
warped roof sheathing arizonahiker Roofing 13 11-17-2005 01:53 AM
Roof Sheathing Acceptable Tolerances? claypj Roofing 2 08-15-2005 04:16 PM
