How To Add Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-22-2010, 01:11 PM   #1
How to add soffits
I have an old 1880 house cape cod style, the second floor the half the ceiling is sloped in each room because of the pitch of the roof. There was minimal insulation blown in the attic, but when they did it they also filled the gap from the soffits to the attic. How do i go about removing the blown in insulation from the gap and then reinsulating it? Remember this gap between the rafters is only 24" and is like 7 ' long or so. Or do i not bother?
In the attic we did add more batt insulation but we still got some ice damns over the winter.
Current venting is jut two small gables on the attic. the attic itself is only about 40' x 15'.
I also plan on redoing the roof this summer. Would it be easier just to take some the boards off from the rough adding in baffles all along the cavity then adding plywood on the top?
bigal0043 is offline   Reply With Quote
Old 03-22-2010, 01:38 PM   #2
Another thought i had was could i shim the rough? So say i take all the old shingles off and add like a 1" or 2" shim from the soffit to the ridge over every joist, cutting a hole into the soffit and into the attic. Then add plywood to the top of the shims, This would leave a 1 or 2 inch gap for air to move under the shingles without having to mess with the insulation. Would this work?
Old 03-22-2010, 02:50 PM   #3
Commercial Roofing
AaronB's Avatar
If you're doing the roof, I have dome exactly this myself... I have insulated the angled ceiling on Cape Cod style homes by removing the roof decking (sheathing) over the angled part, removing the insulation on the ceiling, using closed cell spray foam insulation on said ceiling since you can get great R-value from closed cell spray foam, and continuing with the roofing process.
You would need 2x6 rafters or better in order to attain the necessary insulation while still leaving an in or so gap for under the roof deck ventilation.
You should be able to set this up relatively inexpensively through a spray foam insulator if all he has to do is show up, heat the materials he is using, and spray. I do my own, but only because I have spray foam equipment.
Hope this helps.
__________________ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Building soffits around ducts/support vseven Building & Construction 1 08-13-2010 01:55 PM
Fireblock basement soffits NE78FJ40 Building & Construction 4 03-07-2010 06:44 PM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 10:31 AM
Soffits - dealing with my design blunder shtoink Building & Construction 7 08-01-2008 08:01 PM
Adding attic insulation and cutting soffits a DIY job? drh Roofing/Siding 15 12-31-2007 07:47 PM
