Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-02-2008, 01:00 PM   #1
House Shingle Repair after Roofing Job
We had a new roof put on the summer. When the old roof was taken off, it was so thick it left a big gap between the bottom of the house shingles and the porch roof. The contractor finally sent someone out to fix it. Here is a picture of what the area looks like now. The carpenter said this gap needs to be there because otherwise the rainwater will rot the house shingles.
My sister says the area in the gap will rot. I emailed the contractor and sent him pictures of the job his workman did and he said yes, that is the way it is supposed to be done. The flashing is inside there.
Please help.
Thank you.
Loretta
bubblegummom is offline   Reply With Quote
Old 12-02-2008, 01:25 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As long as their is flashing properly installed underneath the area, The siding is installed correctly. There needs to be a gap there for the rain water. Your sister does not know what she is talking about.
Example: http://toolbelt.buildiq.com/tool-doc...ChimneyCHK.pdf
- Build Well -
Old 12-02-2008, 03:46 PM   #3
Residential Roofer
Slyfox's Avatar
I agree with AtlanticWBConst,
if done properly there will always be a gap between the roof shingles and siding and the gap doe's not seem to high/wide/large to me either.
Not sure about the flashing at the head wall tho, below the windows,
it appears to be lifted up and it should not be,
wind driven precipitation could make it's way in there.
God Family Country Work Play
Slyfox is offline   Reply With Quote
Old 12-02-2008, 08:21 PM   #4
Doing This Way Too Long
I third that motion. WB pretty much summed it all up for you. From that picture it looks like the contractor did some decent work providing the flashing behind it is done properly.
OldNBroken is online now   Reply With Quote
Old 12-02-2008, 08:56 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
I also agree with all. from what you have shown, It looks like a good job. BOB
Old 12-03-2008, 10:41 AM   #6
Originally Posted by Slyfox View Post
...Not sure about the flashing at the head wall tho, below the windows,
To me, that looks like the end cap on the ridge, not fastened.
If it is, then it should be faced nailed and the nail covered with roof sealant.
- Build Well -
Old 12-03-2008, 11:28 AM   #7
Thank you AtlanticWBConst., buletbob, OldNBroken and Slyfox, for your expertise, reassurances and advice!
Loretta
Old 12-07-2008, 02:31 PM   #8
Commercial Roofing
AaronB's Avatar
It looks to me to be a darn good job.
The ridge cap looks like how I do mine with Timbertex. The hip/under cap is cut, wrapped and sealed, and the first ridge cap is designed to hang past a wee bit. Never had a problem.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
need advice of choosing the proper roofing shingle product nc_yella Roofing 10 11-19-2008 04:49 PM
"New: House, and need some advise... dcd22 General Discussion 9 06-17-2008 08:12 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
Older house, no soffit vents- what to do? nebben Roofing 3 01-24-2007 03:37 PM
