House Gutters Flowing Back Over Eaves - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-05-2010, 06:26 PM   #1
House gutters flowing back over eaves
Newly installed house gutters higher at front than back with overflow facility at front.
The gutters are fixed almost as high as the eaves due to screen enclosure roof height.
The screen enclosure has its own gutter system and downpipes as does the house.
Heavy rain causes the flow to flow over the back of the house gutter and flood the scren closure.
Have tried sealing the gaps with no success as the water finds its way down the house side of the eave and then into the screen enclosure.
Is there aproduct or ideas as to how I can fix this ongoing problem?
Thanks in advance
haveago is offline   Reply With Quote
Old 03-05-2010, 06:27 PM   #2
Learning by Doing
Leah Frances's Avatar
Pics would really help in this situation.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-05-2010, 06:45 PM   #3
Where are you located ?
Pics would help
Usually roof flashing/drip edge should direct water into the gutter
The gutters should be installed near level
If they can't handle the volume in downpours then you may need bigger gutters
Old 03-06-2010, 09:08 AM   #4
Commercial Roofing
AaronB's Avatar
Is the front of the gutter taller than the rear? Most gutters are engineered to facilitate flow over the front in certain situations, so that this doesn't happen.
If not, then are your gutters pitched the wrong way. away from the downspout? Some questions need to be answered.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Sloping Floor and back half of the house. Help! mikeinfrisco Building & Construction 1 01-22-2005 08:50 AM
