-   -   Hot Attic (http://www.diychatroom.com/f9/hot-attic-2634/)
mdlbldrmatt135 05-31-2006 02:27 PM
Hot Attic
I have a Home that was re-roofed 2 years ago. Ridgeventing is in place but it is Still really Hot in there. There Are no Soffet vents as there's no Overhang (gutters would block them) What can be done to try to cool it down in the attic. The ptoblem is the fact that the Home is a Split level and the rooms on the front of the house have about 6' of Sloped ceiling (insulated but not vented) There's no moisture problems, and when the roof was re done I had them install 3 "rows" of Ice & Water barrier up from the eave line......
redline 05-31-2006 02:48 PM
Install an attic fan-gable fan...
without any soffit vents the ridge vents have little means to circulate the air.
oakmontoz 06-02-2006 07:41 AM
ridge vent and roof-mounted exhaust fan
Similar situation: ridge vent but no soffit vents. However, a roof-mounted exhaust is also in place, but I'm beginning to think it's not serving its purpose. There are gables at each end of the attic with open & non-moving louvers. Would I be better off having fans at those? Should I exhaust air or draw outside air in?
mdlbldrmatt135 06-02-2006 08:06 AM
I'm contemplating using a fan at each Gable now one drawing in and one blowing out
tribe_fan 06-02-2006 09:46 AM
I'd like to see a Roofing Pro chime in - but I would think that if you have Ridge vents already installed - you would want the Gables to blow in ?
redline 06-02-2006 12:05 PM
The gable fans that I have installed usually blow (push) the air out of the roof area.
If you have two or more gable vents, then the best spot to put it in is on the hotter side of the house. You want the fan to draw in air that is cooler, if possible. The fan should pull air in from the other gable vents that are on the cooler side of the house.
