Hopefully My Last Roof Issuse (for This Year)! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-27-2011, 02:20 AM   #1
Rewards Points: 956
Wink
Hopefully my last roof issuse (for this year)!
Alright gentlemen here we go again. First I want to say big thanks to everyone that chimed in with their input when I got my roof replaced last year. Went up last week and so far everything seems to look good.
Now quick background. we decided to use spray foam for insulation, so we demo'ed the ceilings. That's when I discovered the bathroom fan has no exhaust duct connected to it! Originally I was going to run a 5ft metal pipe through the wall, but upon measuring it's not feasible because the pipe will run right into fascia board for the gutters. So new plan is to run the duct through roof, where you guys come in (again)
IN my head it's simple: drill pilot hole through decking and shingle from below. use hole saw to drill the 6in hole. install pipe through the hole and cap it off. My main concern : is there a better type of roof cap I should use? and what's the best way to flash it? should I use new shingles or overlap over existing ones. Thanks!
federer is offline   Reply With Quote
Old 05-27-2011, 02:23 AM   #2
Rewards Points: 956
something like this should work right?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
this is the pipe i am going to use:
http://www.homedepot.com/h_d1/N-5yc1v/R-100172309/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Edit-the run will only be about a foot. I don't have an attic!
Old 05-27-2011, 08:50 AM   #3
MJW
Here is what you need. Don't leave any slack in the flex pipe and keep it vertical.
MJW is offline   Reply With Quote
The Following 2 Users Say Thank You to MJW For This Useful Post:
seeyou (05-27-2011), Slyfox (05-28-2011)
Old 05-28-2011, 02:22 AM   #4
Rewards Points: 956
thanks for the suggestion-can i use the aluminum pipe instead of the flexible one? because in time it wont hold up as well.
Old 06-01-2011, 12:27 AM   #5
Rewards Points: 956
no other input??
Old 06-01-2011, 03:31 AM   #6
Rewards Points: 956
?why did you post in my thread?
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 08:40 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Flat roof resurface--EPDM, Torch Down, Cold Applied bitumen mgfuns Off Topic 3 07-07-2010 01:10 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
