Holes In Osb Decking On Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-30-2012, 10:38 PM   #1
holes in osb decking on roof
I am building a new home and the crew that put on the decking took a hammer and put 5 holes in the decking to pull their air hoses through the roof(unbelievable). the contractor did not catch it, I did, AFTER they had put on the felt and a GAF HD 30year shingle. The contractor filled the holes with construction adhesive and put a 2x6 between the rafters for support over the holes. Is this good enough or should I make him tear the sections off and do it right? Naturally worried about the shingles matching. they have been on about a month.
Piksnna is offline   Reply With Quote
Old 12-31-2012, 05:55 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
1" holes? No issue. 6" holes"? An issue.
tinner666 is offline   Reply With Quote
Old 12-31-2012, 07:17 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
+1 agree with Tinner. I normally bring hoses thru at the ridge.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
jagans (12-31-2012)
Old 12-31-2012, 10:15 AM   #4
Roofmaster
Rewards Points: 2,210
First of all, what stupid bastards these guys were. Second of all, the contractor didn't catch it, because he allows it all the time.
At the end of the day, if they had top patched the holes with a piece of 24 gage galvanized sheet metal set in roof cement, and fastened only across the top, you are OK up to about 8 inches. I don't get the 2 x 6 because you still have a void above it, the thickness of the sheathing.
Hoses through ridge opening makes very good sense from every standpoint.
Old 12-31-2012, 01:06 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
I also agree with Tinner,,,But your telling me nobody cut the bottom out of a coffee can or covered the hole with a couple license plates ? They do that all the time here.
Roofmaster417 is offline   Reply With Quote
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 09:44 PM
Help with repairing holes in roof due to satellite installation amodoko Roofing/Siding 5 10-24-2012 09:37 PM
Spray Foam insulation under roof decking federer Insulation 30 10-29-2011 09:22 PM
cutting vent holes in roof rgee Roofing/Siding 1 09-22-2010 06:02 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
