Hole In Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 07:55 PM   #1
Rewards Points: 150
Send a message via AIM to Bocolo
Hole in Roof
Hello,
I was just in the attic and found two holes that go right through the roof. Well I did not really "find" them, I drilled them by mistake What can I use to cover these up? Preferably from the inside of the house. It is kind of dangerous to go up in the roof (three stories) especially in the middle of winter. Thanks for your time in advanced.
Bocolo is offline   Reply With Quote
Old 02-08-2009, 08:10 PM   #2
I guess drilling them out would be one way to find them
How big are the holes??
I'd cut a piece of plywood bigger then the holes
Pile some roofing caulking on the plywood where the holes are
Then push the plywood up & fasten in place with screws SMALLER then the roof decking
Old 02-08-2009, 08:17 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
for an emergency repair on small holes you could use a tube of roof cement and try to inject it into the holes.But i would try to get up there sooner than later and either change those shingles or a little roof cement
Tom Struble is offline   Reply With Quote
Old 02-08-2009, 09:17 PM   #4
Rewards Points: 150
Thanks for your time and input. The holes are 5/8". I will combo both your ideas until we get better weather. This New England weather gets crazier every year. Thanks again.
Old 02-08-2009, 09:21 PM   #5
good luck and be careful
Old 02-08-2009, 09:28 PM   #6
Rewards Points: 150
Thanks again. I am so glad I found this forum. Very helpful and informative people.
Old 02-08-2009, 10:53 PM   #7
Doing This Way Too Long
Rewards Points: 532
Come on, are we gonna let him get away without explaining WHY and HOW the holes got there????????????????
Inquiring minds want to know.
OldNBroken is offline   Reply With Quote
Old 02-09-2009, 05:17 AM   #8
Rewards Points: 150
I was afraid someone would ask. That's why I started saying "I found". I was drilling the top plate for two new outlets, the roof is slanted and the is about 1 1/2 inch clearance between top plate and roof. Went right thru both with a new bit. Scuba's comment about "one way of finding a hole" made me laugh. I thought that was going to be it, but NOOOO you had to come along and ask. Anyway, lesson learned. As long as I learn something new I don't mind making mistakes.
Old 02-10-2009, 06:10 AM   #9
the roofing god's Avatar
Send a message via MSN to the roofing god
LOL,Least you were honest about it !
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 02-10-2009, 09:47 AM   #10
Rewards Points: 150
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
