Hole In Metal Roof... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-16-2014, 07:59 PM   #16
Chatsworth's Avatar
Rewards Points: 32
Here's the roof.I inserted a pop rivet to indicate the hole and there is a low spot thanks to the warped brace.It's not very low,but it is the roof's lowest spot,thus that's where the water will pool and go through the hole.
Chatsworth is offline   Reply With Quote
Old 02-25-2014, 04:51 PM   #17
Hole
Since you are going to the junkyard,why not just get a piece of sheet metal that will fit on the roof and put it on top of the hole on top of the roof, then just sealing it with something like climaclear or even silicone would work. Even if you got a sheet and just put it up there with some roofing screws, that way those don't leak either. You could probably go with stitch screws (lap screws) if there isn't anything to screw to. That way you wouldn't have to worry about screwing into the structure. Just metal to metal. Then seal all around the square sheet. Sort of like in the picture below, but pretend that the shingle roof is your roof.
TedLeger is offline   Reply With Quote
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
metal roof conversion ionized Roofing/Siding 5 06-19-2012 08:57 PM
How to repair hole in Standing Seam Metal Roof DaveMorris Roofing/Siding 4 04-18-2009 11:18 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
